Salta al contenuto principale
Nerf Zombie Strike Crossbow Cocking Mechanism Replacement
Cosa ti serve
  1. Nerf Zombie Strike Crossbow Cocking Mechanism Replacement, Cocking Mechanism: passo 1, immagine 1 di 1
    • There are 19 1.0 cm screws.
  2. Nerf Zombie Strike Crossbow Cocking Mechanism Replacement: passo 2, immagine 1 di 1
    • The cocking device air to be built up inside the Nerf crossbow, which generates the force needed to propel the darts.
  3. Nerf Zombie Strike Crossbow Cocking Mechanism Replacement: passo 3, immagine 1 di 1
    • Use the screwdriver and unscrew each screw one-by-one placing each screw on the magnetic mat to insure they do not get lost.
  4. Nerf Zombie Strike Crossbow Cocking Mechanism Replacement: passo 4, immagine 1 di 1
    • Separate each part of the Nerf crossbow.
  5. Nerf Zombie Strike Crossbow Cocking Mechanism Replacement: passo 5, immagine 1 di 1
    • Make sure the cocking mechanism is properly aligned with the rest of the Nerf crossbow.
  6. Nerf Zombie Strike Crossbow Cocking Mechanism Replacement: passo 6, immagine 1 di 1
    • The cocking device needs to be attached to the plunger in order to function properly.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 3,649
