Salta al contenuto principale
Nerf Vortex Vigilon Slide Replacement
Cosa ti serve
  1. Nerf Vortex Vigilon Slide Replacement, Removing the slide screws: passo 1, immagine 1 di 1
    • The two slide pieces hold the orange sight in place. Expect that the sight will come off when you remove the slide pieces.
    • Using a screwdriver, carefully unscrew the three #00 1 cm Phillips screws holding the two slide pieces together.
    • Both sides of the slide will come off when the screws are removed.
  2. Nerf Vortex Vigilon Slide Replacement, Removing the slide pieces: passo 2, immagine 1 di 1
    • Lift both slide pieces off of the gun.
Conclusione
Altre 2 persone hanno completato questa guida.
Cara Pew
Membro da: 09/29/14
932 Reputazione
7 Guide realizzate
Cal Poly, Team 13-6, Forte Fall 2014 Membro di Cal Poly, Team 13-6, Forte Fall 2014
CPSU-FORTE-F14S13G6
5 Membri
7 Guide realizzate
2Commenti sulla guida
Ok so the slide is removed now what? It's still stuck
amanintights1981 - Replica
i was thinking the same thing
Christina TheTurtle -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 9
Tutti i Tempi: 2,432
