Salta al contenuto principale
Nerf Vortex Vigilon Side Cover Disassembly
Solo Prerequisita
Questa guida è destinata a essere usata solo come prerequisito per altre guide. Da sola è incompleta.
Cosa ti serve
  1. Nerf Vortex Vigilon Side Cover Disassembly, Removing the outer screws: passo 1, immagine 1 di 2 Nerf Vortex Vigilon Side Cover Disassembly, Removing the outer screws: passo 1, immagine 2 di 2
    • Remove the twelve #00 1 cm Phillips screws.
    • Because the holes for the screws are deeper than the screw size, some of the screws may not come out even after you have completely unscrewed them. They will come out when you take off the outside cover in the next step, which is okay.
    • Rotate the gun so that the front is facing you to remove the final screw.
  2. Nerf Vortex Vigilon Side Cover Disassembly, Removing the outside cover: passo 2, immagine 1 di 1
    • When removing the cover, the clip attachment and the spring will likely fall out of the gun.
    • Lift the outside cover off of the gun. Only the side where you removed the screws will come off.
    • The magazine will slide down automatically as you remove the cover.
Conclusione
Cara Pew
Membro da: 09/29/14
911 Reputazione
7 Guide realizzate
Cal Poly, Team 13-6, Forte Fall 2014 Membro di Cal Poly, Team 13-6, Forte Fall 2014
CPSU-FORTE-F14S13G6
5 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 42
