Salta al contenuto principale
Nerf Vortex Praxis Projecting Ejector Clip Replacement
Guida Archiviata
Questa guida è mantenuta solo per scopi storici. Usa la versione aggiornata della guida per eseguire la riparazione.
Cosa ti serve
  1. Nerf Vortex Praxis Projecting Ejector Clip Replacement, Projecting Ejector Clip: passo 1, immagine 1 di 1
    • Start by taking out all of the screws for the casing of the gun. Using the PH #00 screwdriver, unscrew all four 1.3-cm screws in the pump.
  2. Nerf Vortex Praxis Projecting Ejector Clip Replacement: passo 2, immagine 1 di 1
    • Take out all of the screws with a Phillips screwdriver. Using a PH #00 Screwdriver, unscrew all fourteen, 1.2-cm screws.
  3. Nerf Vortex Praxis Projecting Ejector Clip Replacement: passo 3, immagine 1 di 1
    • Remove the small stock at the back end of the gun by removing two, 1-cm screws.
  4. Nerf Vortex Praxis Projecting Ejector Clip Replacement: passo 4, immagine 1 di 1
    • Pull apart the case of the gun.
  5. Nerf Vortex Praxis Projecting Ejector Clip Replacement: passo 5, immagine 1 di 1
    • Remove the 1.2 cm Phillips screw and the silver 1.1 cm Phillips screw at the front of the gun.
    • Remove the silver 1.1 cm Phillips screw next to the first screw.
  6. Nerf Vortex Praxis Projecting Ejector Clip Replacement: passo 6, immagine 1 di 1
    • Remove the two 0.7 cm screws that are towards the back of the case.
  7. Nerf Vortex Praxis Projecting Ejector Clip Replacement: passo 7, immagine 1 di 1
    • Pull out the white piece which is the ejector component of the rifle.
Conclusione
IUPUI, Team 3-1, Harley Spring 2016 Membro di IUPUI, Team 3-1, Harley Spring 2016
IUPUI-HARLEY-S16S3G1
3 Membri
5 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 387
