Salta al contenuto principale
Nerf Recon CS-6 Plunger Replacement
Cosa ti serve
  1. Nerf Recon CS-6 Plunger Replacement, Remove Magazine: passo 1, immagine 1 di 1
    • Skip this step if magazine is already removed.
    • Pull slide back.
    • Pull backwards on release buttons and slide magazine out.
    • Push slide back forward and pull trigger.
  2. Nerf Recon CS-6 Plunger Replacement, Remove Visible Screws: passo 2, immagine 1 di 1
    • Use the Phillips #0 Screwdriver to remove these 9 screws.
    • All screws marked in red are 9.6 mm Phillips #0 screws.
    • Note that left most screw is longer than the rest and is a 18.6 mm Phillips #0 screw.
  3. Nerf Recon CS-6 Plunger Replacement, Remove Hidden Screws: passo 3, immagine 1 di 2 Nerf Recon CS-6 Plunger Replacement, Remove Hidden Screws: passo 3, immagine 2 di 2
    • Pull slide back to reveal more screws.
    • Remove these 2 screws.
    • Push slide forward.
    • Pull trigger to release compression of the main spring.
    • Screws are 9.6 mm Phillips #0.
    • Pulling the trigger will keep spring from launching out of the gun when the two halves are separated.
  4. Nerf Recon CS-6 Plunger Replacement, Remove Plunger Cap: passo 4, immagine 1 di 1
    • Remove the screws on the plunger cap.
    • Tug the plunger cap off.
  5. Nerf Recon CS-6 Plunger Replacement, Remove Slide Screws: passo 5, immagine 1 di 1
    • Remove the 2 screws on the slide.
    • Hold the two halves of the gun together to prevent any springs from launching out.
  6. Nerf Recon CS-6 Plunger Replacement, Split the Gun in Half: passo 6, immagine 1 di 2 Nerf Recon CS-6 Plunger Replacement, Split the Gun in Half: passo 6, immagine 2 di 2
    • Pull the gun apart at the middle seam.
    • Watch for any springs that might launch out.
  7. Nerf Recon CS-6 Plunger Replacement, Remove Spring: passo 7, immagine 1 di 2 Nerf Recon CS-6 Plunger Replacement, Remove Spring: passo 7, immagine 2 di 2
    • Pull the spring out the back of the gun.
  8. Nerf Recon CS-6 Plunger Replacement, Removing Plunger Guide: passo 8, immagine 1 di 1
    • Lift the plunger guide straight up out of the gun.
  9. Nerf Recon CS-6 Plunger Replacement, Remove Plunger: passo 9, immagine 1 di 1
    • Pull the plunger out the back of the gun off of the inner piece.
  10. Nerf Recon CS-6 Plunger Replacement, Remove  Other Half of Plunger: passo 10, immagine 1 di 1
    • Pull the remaining half of the plunger out the back of the gun.
Conclusione
Altre 2 persone hanno completato questa guida.
Baylor, Team 8-14, Williams Fall 2014 Membro di Baylor, Team 8-14, Williams Fall 2014
BU-WILLIAMS-F14S8G14
3 Membri
6 Guide realizzate
Un commento
Do you know anywhere that you can buy a replacement plunger? Thanks
Angela Hirschi - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 11
Tutti i Tempi: 4,782
