Salta al contenuto principale
Nerf N-Strike Firestrike Firing Trigger Replacement
Cosa ti serve
  1. Nerf N-Strike Firestrike Firing Trigger Replacement, Remove battery cover: passo 1, immagine 1 di 1
    • Use a #1 Phillips screwdriver to remove the 10 -mm screw that secures the battery plate, then remove the battery cover using your hands.
  2. Nerf N-Strike Firestrike Firing Trigger Replacement: passo 2, immagine 1 di 2 Nerf N-Strike Firestrike Firing Trigger Replacement: passo 2, immagine 2 di 2
    • Slide out the two AAA batteries using your fingers.
  3. Nerf N-Strike Firestrike Firing Trigger Replacement, Blaster Casing: passo 3, immagine 1 di 1
    • Remove the seven 10-mm black Phillips screws from the blaster casing with a #1 Phillips Screwdriver.
  4. Nerf N-Strike Firestrike Firing Trigger Replacement: passo 4, immagine 1 di 2 Nerf N-Strike Firestrike Firing Trigger Replacement: passo 4, immagine 2 di 2
    • Slowly pull apart the blaster casing, starting at the battery location.
    • Keep pulling apart slowly until it separates completely. Be cautious as to not send the internal components flying.
  5. Nerf N-Strike Firestrike Firing Trigger Replacement: passo 5, immagine 1 di 2 Nerf N-Strike Firestrike Firing Trigger Replacement: passo 5, immagine 2 di 2
    • For reassembly, ensure that the chrome nut gets put back in the proper location, signified by the red box.
    • For reassembly, ensure that all the parts are lined up correctly on the dowels, signified by the four orange boxes.
    • For reassembly, note the location of the springs as highlighted in the second photo.
  6. Nerf N-Strike Firestrike Firing Trigger Replacement, Firing Trigger: passo 6, immagine 1 di 2 Nerf N-Strike Firestrike Firing Trigger Replacement, Firing Trigger: passo 6, immagine 2 di 2
    • Remove the firing trigger by grabbing the trigger with your fingers and pulling it up and out.
Conclusione
Altre 4 persone hanno completato questa guida.
Jong Wan Kim
Membro da: 04/22/15
422 Reputazione
2 Guide realizzate
Cal Poly, Team 15-6, Amido Spring 2015 Membro di Cal Poly, Team 15-6, Amido Spring 2015
CPSU-AMIDO-S15S15G6
3 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 10
Tutti i Tempi: 2,993
