Salta al contenuto principale
Nerf N-Strike Elite Strongarm Outer Shell Replacement
Solo Prerequisita
Questa guida è destinata a essere usata solo come prerequisito per altre guide. Da sola è incompleta.
Cosa ti serve
  1. Nerf N-Strike Elite Strongarm Outer Shell Replacement, Outer Shell: passo 1, immagine 1 di 2 Nerf N-Strike Elite Strongarm Outer Shell Replacement, Outer Shell: passo 1, immagine 2 di 2
    • Lay the Nerf Strongarm on its side, left side facing up.
  2. Nerf N-Strike Elite Strongarm Outer Shell Replacement: passo 2, immagine 1 di 2 Nerf N-Strike Elite Strongarm Outer Shell Replacement: passo 2, immagine 2 di 2
    • Locate the 12 Philips head screws and remove them: Head Diameter= 4.3mm, Thread Pitch= 1mm, Screw Length= 8mm
  3. Nerf N-Strike Elite Strongarm Outer Shell Replacement: passo 3, immagine 1 di 1
    • Before removing the cover, make sure to first remove the cover for the cocking mechanism. The top half is freely removable.
    • The other half of the cocking mechanism is connected with a spring which may slide off the blaster. Be advised this is normal but worth watching to avoid damaging the spring.
  4. Nerf N-Strike Elite Strongarm Outer Shell Replacement: passo 4, immagine 1 di 1
    • At this time, remove the blaster cover to reveal its internals.
    • If the blaster is resting on its side, the barrel may shift slightly as it is leaning on itself (seen in the image). This is normal but should be handled with care to keep the blaster together.
  5. Nerf N-Strike Elite Strongarm Outer Shell Replacement: passo 5, immagine 1 di 1
    • Once the screws have been removed, lift the top half of the gun off.
    • Notice, the gray colored piece must be removed first in order for the larger half to be removed.
    • Take care and try not to lose any smaller pieces as you open it up.
    • Locking tab for attachments.
Conclusione
USF Tampa, Team 5-4, Blackwell Fall 2015 Membro di USF Tampa, Team 5-4, Blackwell Fall 2015
USFT-BLACKWELL-F15S5G4
4 Membri
13 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 23
Tutti i Tempi: 217
