Salta al contenuto principale
Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement
Cosa ti serve
  1. Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement, Case Disassembly: passo 1, immagine 1 di 1
    • While holding the blaster, rotate the barrel assembly in the counter-clockwise direction and pull away from the blaster.
  2. Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement: passo 2, immagine 1 di 1
    • Remove the stock of the blaster by pushing the orange tabs downward while pulling the stock away from the blaster.
  3. Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement: passo 3, immagine 1 di 1
    • Remove the magazine from the blaster by forcing the sliding mechanism backwards, pushing the orange tabs downward, and pulling the magazine away.
  4. Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement: passo 4, immagine 1 di 2 Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement: passo 4, immagine 2 di 2
    • Remove the stock attachment point by removing the two 8mm Phillips head screws.
  5. Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement: passo 5, immagine 1 di 2 Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement: passo 5, immagine 2 di 2
    • Remove the eleven 8mm and two 10mm Phillips head screws from the left side of the blaster, and carefully remove the outer casing.
    • Two of the screws must be removed with the sliding mechanism in the forward position. Another two must be removed with the sliding mechanism in the back position.
    • There are several springs that may become displaced during this procedure. Proceed with the utmost caution.
  6. Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement, Air Chamber: passo 6, immagine 1 di 1
    • The firing spring may be energized. If so, carefully release and spring pressure before proceeding.
    • While holding down the white air chamber, pull the firing spring backwards to remove it from the blaster.
  7. Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement: passo 7, immagine 1 di 1
    • Slide the white air chamber forward and remove the white alignment bracket.
  8. Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement: passo 8, immagine 1 di 1
    • Remove white air chamber by depressing the orange trigger apparatus and pulling backwards off of the barrel.
Conclusione
Altre 17 persone hanno completato questa guida.
ericharman
Membro da: 03/02/16
1.422 Reputazione
5 Guide realizzate
4 Commenti
Where did we found the pièces??
Albert Einstein - Replica
where i can buy for spare part “air chamber”?
sabeni83_king - Replica
this tutorial helped A LOT
Daniel MacDonald - Replica
OK I've removed the air chamber now what?
camper234 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 49
Tutti i Tempi: 20,440
