Salta al contenuto principale
Nerf N-Strike Elite Retaliator Barrel Replacement
Cosa ti serve
  1. Nerf N-Strike Elite Retaliator  Barrel Replacement, Remove Barrel: passo 1, immagine 1 di 1
    • While holding the blaster, rotate the barrel assembly in the counter-clockwise direction and pull away from the blaster.
  2. Nerf N-Strike Elite Retaliator  Barrel Replacement, Remove Grip: passo 2, immagine 1 di 1
    • Slide the hand grip assembly toward the end of the barrel and off the barrel assembly.
    • This may require more force than anticipated.
  3. Nerf N-Strike Elite Retaliator  Barrel Replacement, Remove Barrel Cap: passo 3, immagine 1 di 1
    • Disassemble the orange barrel cap by removing two 8mm Phillips screws.
  4. Nerf N-Strike Elite Retaliator  Barrel Replacement, Disassemble Barrel Assembly: passo 4, immagine 1 di 1
    • Disassemble the barrel assembly by removing four 8mm Phillips screws from the blue barrel housing.
    • There are springs that may become displaced when the barrel housing is removed. Proceed with caution.
  5. Nerf N-Strike Elite Retaliator  Barrel Replacement, Replace Barrel: passo 5, immagine 1 di 1
    • Remove the orange barrel from the assembly.
Conclusione
Altre 6 persone hanno completato questa guida.
ericharman
Membro da: 03/02/16
1.422 Reputazione
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 18
Tutti i Tempi: 11,758
