Introduzione
A damaged barrel may negatively accuracy and overall performance of your rifle. in severe cases it may prevent your rifle from firing all together. This guide shows you how to access and replace the barrel of the Nerf gun.
Cosa ti serve
Looking from the rear of the rifle, remove the two 10 mm phillips screws holding the orange cap to the butt of the rifle.
Pull off the orange cap.
With the rifle barrel pointing left, remove the two 8 mm phillips screws holding the slide mechanism together.
Remove the three 10 mm phillips screws from the bottom of the slide mechanism.
Separate and remove the two halves of the slide mechanism.
