Salta al contenuto principale
Nerf N-Strike Deploy CS-6 Dart Tooth Replacement
Cosa ti serve
  1. Nerf N-Strike Deploy CS-6 Dart Tooth Replacement, Dart Tooth: passo 1, immagine 1 di 1
    • Before releasing the device in Stealth mode, take out hidden screws as shown
    • Extend the device in Stealth Mode by pressing the button found on the handle.
  2. Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: passo 2, immagine 1 di 3 Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: passo 2, immagine 2 di 3 Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: passo 2, immagine 3 di 3
    • Take out the screws from the pump.
    • Proceed to take out the other screws from the device to take off the cover.
    • For the pump, the screw's length extends out to 1.9 cm. The majority size of the screws extend out to 1.3 cm.
  3. Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: passo 3, immagine 1 di 2 Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: passo 3, immagine 2 di 2
    • Once the screws are out, you are able to take the cover piece off.
    • Proceed to remove the screws
    • Taking off those screws are vital in replacing the dart tooth.
  4. Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: passo 4, immagine 1 di 1
    • Carefully place cover piece above the device.
  5. Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: passo 5, immagine 1 di 1
    • Unscrew as shown to aid in the replacement.
  6. Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: passo 6, immagine 1 di 1
    • To take out the dart tooth, push the spring to the left.
    • The dart tooth should pop out with ease.
  7. Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: passo 7, immagine 1 di 1
    • Once pulled away from the device, take off the orange piece connected to the darth tooth
    • The piece can be identified with the spring.
  8. Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: passo 8, immagine 1 di 1
    • You should now be able to pull apart the dart tooth from the device.
    • The piece that has been pulled away will have a type of lubrication. If this piece requires replacement, it will slide on with ease.
  9. Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: passo 9, immagine 1 di 1
    • Make any adjustment to the dart tooth as seen. May be pulled either up or down.
    • Place in the replacing piece in order to fix the darth tooth
  10. Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: passo 10, immagine 1 di 3 Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: passo 10, immagine 2 di 3 Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: passo 10, immagine 3 di 3
    • Place back on the orange piece with the spring to its original spot on the dart tooth.
    • While setting in the dart tooth back into place, the small spring on the yellow piece must be placed in its compartment as shown.
    • Place back cover pieces in order to secure the screws back into place.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 18
Tutti i Tempi: 2,950
