Salta al contenuto principale
Nerf Dart Tag Furyfire Pump Track Replacement
Cosa ti serve
  1. Nerf Dart Tag Furyfire Pump Track Replacement, Remove the screws: passo 1, immagine 1 di 1
    • Using a 00 Phillips screwdriver, remove all screws from the front panel. The screws have a length of .95 cm.
  2. Nerf Dart Tag Furyfire Pump Track Replacement, Remove Panel: passo 2, immagine 1 di 1
    • After the screws have been removed, gently lift the panel from the gun and set it aside.
  3. Nerf Dart Tag Furyfire Pump Track Replacement, Remove Black Cylinder: passo 3, immagine 1 di 1
    • Locate the black cylinder connected to the large spring near the top of the device.
    • Once located, push the black cylinder against the spring and lift it out of the device.
  4. Nerf Dart Tag Furyfire Pump Track Replacement, Remove Spring: passo 4, immagine 1 di 2 Nerf Dart Tag Furyfire Pump Track Replacement, Remove Spring: passo 4, immagine 2 di 2
    • Using your hand, lift the large spring and attached plastic stabilizing piece out of the gun and set aside.
    • Ensure that the small spring connected to the stabilizing piece remains connected.
  5. Nerf Dart Tag Furyfire Pump Track Replacement, Remove Pump Handle: passo 5, immagine 1 di 1
    • Remove the two screws circled in blue. They are .95 cm in length.
    • Remove the three screw circled in green. They are .7 cm in length.
  6. Nerf Dart Tag Furyfire Pump Track Replacement, Remove the Pump Handle: passo 6, immagine 1 di 1
    • Once all of the screws have been removed lift the pump handle off and set it aside.
  7. Nerf Dart Tag Furyfire Pump Track Replacement, Remove Attached Spring: passo 7, immagine 1 di 2 Nerf Dart Tag Furyfire Pump Track Replacement, Remove Attached Spring: passo 7, immagine 2 di 2
    • In order to remove the white plastic holder, you must remove the spring that keeps it in place. Using a 00 Phillips screwdriver, carefully remove the screw while holding the spring in place.
  8. Nerf Dart Tag Furyfire Pump Track Replacement, Disengage White Piece: passo 8, immagine 1 di 1
    • Using a plastic opening tool, lift the white piece out of the gun and set it aside.
  9. Nerf Dart Tag Furyfire Pump Track Replacement, Remove the Pump Track: passo 9, immagine 1 di 2 Nerf Dart Tag Furyfire Pump Track Replacement, Remove the Pump Track: passo 9, immagine 2 di 2
    • Using your hand, slide the track out of the gun by pulling it away form the device.
Conclusione
USF Tampa, Team 11-2, Blackwell Fall 2014 Membro di USF Tampa, Team 11-2, Blackwell Fall 2014
USFT-BLACKWELL-F14S11G2
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 460
