Salta al contenuto principale
Nerf Dart Tag Furyfire Large Spring Replacement
Cosa ti serve
  1. Nerf Dart Tag Furyfire Large Spring Replacement, Remove the screws: passo 1, immagine 1 di 1
    • Using a 00 Phillips screwdriver, remove all screws from the front panel. The screws have a length of .95 cm.
  2. Nerf Dart Tag Furyfire Large Spring Replacement, Remove Panel: passo 2, immagine 1 di 1
    • After the screws have been removed, gently lift the panel from the gun and set it aside.
  3. Nerf Dart Tag Furyfire Large Spring Replacement, Remove Black Cylinder: passo 3, immagine 1 di 1
    • Locate the black cylinder connected to the large spring near the top of the device.
    • Once located, push the black cylinder against the spring and lift it out of the device.
  4. Nerf Dart Tag Furyfire Large Spring Replacement, Remove Spring: passo 4, immagine 1 di 2 Nerf Dart Tag Furyfire Large Spring Replacement, Remove Spring: passo 4, immagine 2 di 2
    • Using your hand, lift the large spring and attached plastic stabilizing piece out of the gun and set aside.
    • Ensure that the small spring connected to the stabilizing piece remains connected.
Conclusione
USF Tampa, Team 11-2, Blackwell Fall 2014 Membro di USF Tampa, Team 11-2, Blackwell Fall 2014
USFT-BLACKWELL-F14S11G2
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,402
