Salta al contenuto principale
Necklace Barrel Clasp Repair
Cosa ti serve
  1. Necklace Barrel Clasp Repair, Necklace Barrel Clasp Repair: passo 1, immagine 1 di 2 Necklace Barrel Clasp Repair, Necklace Barrel Clasp Repair: passo 1, immagine 2 di 2
    • Locate the broken part of the ring that attaches through the back of the barrel clasp.
    • Bend the portion of the ring with needle nose pliers until the newly compact ring can be pushed through the barrel clasp and fit snug.
  2. Necklace Barrel Clasp Repair: passo 2, immagine 1 di 1
    • Plug in the electric soldering iron and set the solder temperature to the degrees that suits the melting point of both the soldering wire and the barrel clasp.
    • The soldering iron tip can get extremely hot and will cause severe burns if comes into direct contact with skin. Ensure you keep a safe distance, and wear safety equipment.
    • This method is not recommended for precious metals.
  3. Necklace Barrel Clasp Repair: passo 3, immagine 1 di 1
    • Molten metal is extremely hot and will cause severe burns. Handle the soldering gun with care and keep your distance from the melting metal.
    • Solder the base of the barrel clasp where the metal ring fits in, intersecting the tips of the soldering gun and soldering wire.
    • Ensure the barrel clasp and ring connection is covered, allowing anywhere from 10 to 30 seconds for the bond to harden and cool.
  4. Necklace Barrel Clasp Repair: passo 4, immagine 1 di 1
    • Attach the barrel clasp necklace back together and hold each end of the necklace taught to test the solder strength.
    • Do not pull too hard—the amount of strain may cause the solder to break.
Conclusione
Garrett Key
Membro da: 07/12/17
107 Reputazione
1 Guida realizzata
Texas Tech, Team S1-G5, Rauch Summer 2017 Membro di Texas Tech, Team S1-G5, Rauch Summer 2017
TTU-RAUCH-SU17S1G5
3 Membri
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 55
Tutti i Tempi: 2,274
