Salta al contenuto principale
Neato XV-21 Wheels Replacement
Cosa ti serve
  1. Neato XV-21 Wheels Replacement, Back Panels of Neato XV-21: passo 1, immagine 1 di 1
    • Flip the Neato on its back so the bottom is exposed
    • Unscrew the seven screws.
  2. Neato XV-21 Wheels Replacement: passo 2, immagine 1 di 1
    • Lift the panels to reveal the batteries, brush and fan
    • There should be little to no resistance during this step, do not continue if the pieces do not separate easily
  3. Neato XV-21 Wheels Replacement: passo 3, immagine 1 di 1
    • The Neato's core components are now exposed and ready to be cleaned and/or replaced.
  4. Neato XV-21 Wheels Replacement, Battery: passo 4, immagine 1 di 1
    • Pinch and pull the white connector to disconnect the battery from the device
    • Failure to complete this step could cause electric shock or later complications
    • Lift and remove the battery from the cavity
    • If replacing the battery, make sure to use proper disposal methods.
  5. Neato XV-21 Wheels Replacement, Wheels: passo 5, immagine 1 di 1
    • Pinch and pull the white connector, indicated in the image, to disconnect the wheel from the robot. Repeat for both wheels
  6. Neato XV-21 Wheels Replacement: passo 6, immagine 1 di 1
    • Slide out dowel rod connecting the wheel to the robot.
  7. Neato XV-21 Wheels Replacement: passo 7, immagine 1 di 2 Neato XV-21 Wheels Replacement: passo 7, immagine 2 di 2
    • Lift the wheel so the spring is exposed
    • Pay particular attention to how the wheel is placed to replicate during reinsertion
    • Unhook the spring from robot
    • Lift the wheel from the cavity
Conclusione
Altre 3 persone hanno completato questa guida.
Un commento
Needs to Link to Parts List and a way to Order Parts.
Bill Price - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 10
Tutti i Tempi: 722
