Salta al contenuto principale
Neato Botvac D75 Brushes Replacement
Cosa ti serve
  1. Neato Botvac D75 Brushes Replacement, Brushes: passo 1, immagine 1 di 3 Neato Botvac D75 Brushes Replacement, Brushes: passo 1, immagine 2 di 3 Neato Botvac D75 Brushes Replacement, Brushes: passo 1, immagine 3 di 3
    • To remove the rotary brush simply grasp it firmly and pull it off.
  2. Neato Botvac D75 Brushes Replacement: passo 2, immagine 1 di 3 Neato Botvac D75 Brushes Replacement: passo 2, immagine 2 di 3 Neato Botvac D75 Brushes Replacement: passo 2, immagine 3 di 3
    • Once you have everything out get the plastic opening tool and pry open the large black plastic piece.
    • With a little force it should come out.
    • The boxes show you were the clips are that hold this piece
  3. Neato Botvac D75 Brushes Replacement: passo 3, immagine 1 di 1
    • Once the black piece has been taken out, the brush just comes out easily.
Conclusione
Juan Cornejo
Membro da: 02/15/17
597 Reputazione
5 Guide realizzate
USF Tampa, Team S6-G5, Lacy Spring 2017 Membro di USF Tampa, Team S6-G5, Lacy Spring 2017
USFT-LACY-S17S6G5
4 Membri
10 Guide realizzate
Un commento
I have removed and cleaned the brush but it still won't run due to the error message to clean the brush. The machine has only run 5 or 6 times so brand new machine.
keytkey - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 925
