Salta al contenuto principale
Neato Botvac Connected Right Side Wall Sensor Replacement
Cosa ti serve
  1. Neato Botvac Connected Right Side Wall Sensor Replacement, Right Side Wall Sensor: passo 1, immagine 1 di 3 Neato Botvac Connected Right Side Wall Sensor Replacement, Right Side Wall Sensor: passo 1, immagine 2 di 3 Neato Botvac Connected Right Side Wall Sensor Replacement, Right Side Wall Sensor: passo 1, immagine 3 di 3
    • Flip the Botvac over so that the underside is facing up and the flat front is facing toward you.
    • Remove the four screws lining the front roller using a TR10 Torx screwdriver.
    • Remove the black panel behind and in front of the roller.
    • Gently lift the roller by the right side to remove it.
  2. Neato Botvac Connected Right Side Wall Sensor Replacement: passo 2, immagine 1 di 1
    • Remove the two screws behind the front roller of the robot using a Phillips #2 screwdriver.
    • Remove the battery by lifting it out while pressing down on the wire clip inside the compartment.
  3. Neato Botvac Connected Right Side Wall Sensor Replacement: passo 3, immagine 1 di 3 Neato Botvac Connected Right Side Wall Sensor Replacement: passo 3, immagine 2 di 3 Neato Botvac Connected Right Side Wall Sensor Replacement: passo 3, immagine 3 di 3
    • Pull one side of the front bumper out and then forward toward you. Repeat on the other side to completely detach the front bumper.
  4. Neato Botvac Connected Right Side Wall Sensor Replacement: passo 4, immagine 1 di 2 Neato Botvac Connected Right Side Wall Sensor Replacement: passo 4, immagine 2 di 2
    • Remove the eight screws from the underside of the Botvac using a TR10 Torx screwdriver.
    • Remove the additional two TR10 screws from the top of the Botvac.
    • Remove the dustbin.
  5. Neato Botvac Connected Right Side Wall Sensor Replacement: passo 5, immagine 1 di 3 Neato Botvac Connected Right Side Wall Sensor Replacement: passo 5, immagine 2 di 3 Neato Botvac Connected Right Side Wall Sensor Replacement: passo 5, immagine 3 di 3
    • Pry the clips on the front of the robot apart.
    • Unplug the beige connector with a spudger, working one side at a time until it comes unplugged.
    • Make certain not to not to tear any wires out of the port.
    • Lay the bottom of the robot inside up.
    • Remove the single screw on the right side of the robot using a TR10 Torx screwdriver.
    • Remove the sensor by lifting it straight up.
    • Unplug the connector by pulling firmly on the plastic.
    • Plug the new sensor into the open port.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 114
