Introduzione
This guide will aid you in replacing the wall sensor on your Botvac.
Cosa ti serve
Flip the Botvac over so that the underside is facing up and the flat front is facing toward you.
Remove the four screws lining the front roller using a TR10 Torx screwdriver.
Remove the black panel behind and in front of the roller.
Gently lift the roller by the right side to remove it.
Quasi finito!
Conclusione
