Salta al contenuto principale
Neato Botvac 80 Laser Replacement
Cosa ti serve
  1. Neato Botvac 80 Laser Replacement, Rear Bumper: passo 1, immagine 1 di 1
    • Grab the rear bumper with both hands on either side.
  2. Neato Botvac 80 Laser Replacement: passo 2, immagine 1 di 1
    • Pull the left and right sides away from the machine to unclip the bumper. This requires that you bend the plastic a little bit. Unclip one side a little bit and allow the prong to rest on the side of the machine. Then unclip the other side and pull off the bumper parallel to both sides
  3. Neato Botvac 80 Laser Replacement, Top Face Panel: passo 3, immagine 1 di 2 Neato Botvac 80 Laser Replacement, Top Face Panel: passo 3, immagine 2 di 2
    • Looking from above, remove the two 11mm screws with a torx T10 screwdriver.
  4. Neato Botvac 80 Laser Replacement: passo 4, immagine 1 di 1
    • Begin by placing the robot on it's back and removing the six 11m screws using a Torx T10 screwdriver.
  5. Neato Botvac 80 Laser Replacement: passo 5, immagine 1 di 3 Neato Botvac 80 Laser Replacement: passo 5, immagine 2 di 3 Neato Botvac 80 Laser Replacement: passo 5, immagine 3 di 3
    • To remove the top, you must press in both of the clamps at the same time and push upwards.
    • When removing the top, before you can completely take it off you must unplug the LCD power cable from the motherboard.
  6. Neato Botvac 80 Laser Replacement, Laser: passo 6, immagine 1 di 3 Neato Botvac 80 Laser Replacement, Laser: passo 6, immagine 2 di 3 Neato Botvac 80 Laser Replacement, Laser: passo 6, immagine 3 di 3
    • Lift gently upon the top panel.
    • Unplug the clip located on the right side before completely removing.
  7. Neato Botvac 80 Laser Replacement: passo 7, immagine 1 di 3 Neato Botvac 80 Laser Replacement: passo 7, immagine 2 di 3 Neato Botvac 80 Laser Replacement: passo 7, immagine 3 di 3
    • This black cap spins so may need a hand when unscrewing the screws.
    • Locate and unscrew the four 12 mm screws located in the black cap with the phillips #00 screwdriver.
    • Lift the black cap to reveal the laser.
  8. Neato Botvac 80 Laser Replacement: passo 8, immagine 1 di 3 Neato Botvac 80 Laser Replacement: passo 8, immagine 2 di 3 Neato Botvac 80 Laser Replacement: passo 8, immagine 3 di 3
    • There are two loosely secured black blinders on both the laser and sensor.
    • Gently pull back on the gold laser to remove it from the socket.
    • Unplug the mini LCU clip by gently pulling up and remove the laser.
Conclusione
Altre 4 persone hanno completato questa guida.
USF Tampa, Team 17-5, Blackwell Spring 2017 Membro di USF Tampa, Team 17-5, Blackwell Spring 2017
USFT-BLACKWELL-S17S17G5
3 Membri
12 Guide realizzate
9 Commenti
lol. You don’t need to open it to replace the laser. The top is a clip on. Just pull it and remove 4 screws.
Evgany Vorona - Replica
where do you buy the replacement laser?
Nancy Butler - Replica
I too would like to know where he got a replacement laser.
Anthony Mainini -
where do I buy a replacement laser?
bjurgensen79@gmail.com
Beverly Jurgensen
Beverly Jurgensen - Replica
Where do I buy a replacement laser?
Beverly Jurgensen
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 21
Tutti i Tempi: 8,987
