Salta al contenuto principale
Neato BOTVAC D5 Main Brush Motor Replacement
Cosa ti serve
  1. Neato BOTVAC D5 Main Brush Motor Replacement, Side Brush: passo 1, immagine 1 di 1
    • Turn the Neato Botvac upside down so the brushes and wheels are facing upward.
  2. Neato BOTVAC D5 Main Brush Motor Replacement: passo 2, immagine 1 di 2 Neato BOTVAC D5 Main Brush Motor Replacement: passo 2, immagine 2 di 2
    • Firmly grasp and pull on the side brush and it will pop right off
  3. Neato BOTVAC D5 Main Brush Motor Replacement, Main Roller Brush: passo 3, immagine 1 di 2 Neato BOTVAC D5 Main Brush Motor Replacement, Main Roller Brush: passo 3, immagine 2 di 2
    • Pop the tabs shown on the main brush cover, and then pull. It should come right off. You can put it aside for now.
  4. Neato BOTVAC D5 Main Brush Motor Replacement: passo 4, immagine 1 di 2 Neato BOTVAC D5 Main Brush Motor Replacement: passo 4, immagine 2 di 2
    • The Main brush will pop right out when you attempt to remove it.
    • When replacing the main brush make sure to orient it correctly.
  5. Neato BOTVAC D5 Main Brush Motor Replacement, Main Brush Motor: passo 5, immagine 1 di 2 Neato BOTVAC D5 Main Brush Motor Replacement, Main Brush Motor: passo 5, immagine 2 di 2
    • Pull down the latch under the sensor and then carefully remove it from the unit.
  6. Neato BOTVAC D5 Main Brush Motor Replacement: passo 6, immagine 1 di 2 Neato BOTVAC D5 Main Brush Motor Replacement: passo 6, immagine 2 di 2
    • Flip the unit over and locate the gap next to the motor, on the same side the sensor was removed from. Insert your flathead screwdriver and twist lightly to pop off the motor.
  7. Neato BOTVAC D5 Main Brush Motor Replacement: passo 7, immagine 1 di 1
    • Disconnect the wiring connecting the motor to the circuit board and remove the brush motor.
Conclusione
Laurent Kwan
Membro da: 10/30/23
337 Reputazione
3 Guide realizzate
UMass Dartmouth, Team 3-3, Konn Fall 2023 Membro di UMass Dartmouth, Team 3-3, Konn Fall 2023
UMASSD-KONN-F23S3G3
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 24
Tutti i Tempi: 168
