Salta al contenuto principale
Neato BOTVAC CONNECTED Side Wheel Replacement
Cosa ti serve
  1. Neato BOTVAC CONNECTED Side Wheel Replacement, Battery: passo 1, immagine 1 di 1
    • Place the top of the Neato Botvac Connected against a flat surface.
  2. Neato BOTVAC CONNECTED Side Wheel Replacement: passo 2, immagine 1 di 2 Neato BOTVAC CONNECTED Side Wheel Replacement: passo 2, immagine 2 di 2
    • Remove the two 5.5 mm screws with a Phillips #2 screwdriver.
  3. Neato BOTVAC CONNECTED Side Wheel Replacement: passo 3, immagine 1 di 2 Neato BOTVAC CONNECTED Side Wheel Replacement: passo 3, immagine 2 di 2
    • Using the spudger, remove the panel covering the battery.
  4. Neato BOTVAC CONNECTED Side Wheel Replacement: passo 4, immagine 1 di 3 Neato BOTVAC CONNECTED Side Wheel Replacement: passo 4, immagine 2 di 3 Neato BOTVAC CONNECTED Side Wheel Replacement: passo 4, immagine 3 di 3
    • Gently remove the connecting wires attached to the battery.
    • The wires are attached to the vacuum through a clip.
  5. Neato BOTVAC CONNECTED Side Wheel Replacement: passo 5, immagine 1 di 1
    • Using the spudger, gently remove the battery from the device.
  6. Neato BOTVAC CONNECTED Side Wheel Replacement, Front Roller Brush: passo 6, immagine 1 di 2 Neato BOTVAC CONNECTED Side Wheel Replacement, Front Roller Brush: passo 6, immagine 2 di 2
    • Remove the following screws with a Torx screwdriver:
    • Four 2.3 mm screws.
  7. Neato BOTVAC CONNECTED Side Wheel Replacement: passo 7, immagine 1 di 1
    • Gently remove the thin panel held by the four screws with a spudger.
  8. Neato BOTVAC CONNECTED Side Wheel Replacement: passo 8, immagine 1 di 1
    • Gently remove the two small wheels, and the axles attached to them.
  9. Neato BOTVAC CONNECTED Side Wheel Replacement: passo 9, immagine 1 di 1
    • Gently remove the panel that is on top of the front roller with the spudger.
  10. Neato BOTVAC CONNECTED Side Wheel Replacement: passo 10, immagine 1 di 1
    • Gently remove the front brush.
  11. Neato BOTVAC CONNECTED Side Wheel Replacement, Side Brush: passo 11, immagine 1 di 2 Neato BOTVAC CONNECTED Side Wheel Replacement, Side Brush: passo 11, immagine 2 di 2
    • Gently twist the side brush back and forth.
  12. Neato BOTVAC CONNECTED Side Wheel Replacement: passo 12, immagine 1 di 3 Neato BOTVAC CONNECTED Side Wheel Replacement: passo 12, immagine 2 di 3 Neato BOTVAC CONNECTED Side Wheel Replacement: passo 12, immagine 3 di 3
    • Spin the side brush counter counterclockwise.
  13. Neato BOTVAC CONNECTED Side Wheel Replacement: passo 13, immagine 1 di 1
    • Use the spudger to gently pry up and remove the side brush.
  14. Neato BOTVAC CONNECTED Side Wheel Replacement, Filter: passo 14, immagine 1 di 1
    • Flip the cleaner around and locate the front panel.
  15. Neato BOTVAC CONNECTED Side Wheel Replacement: passo 15, immagine 1 di 1
    • Gently remove the front panel by opening it with a spudger.
  16. Neato BOTVAC CONNECTED Side Wheel Replacement: passo 16, immagine 1 di 2 Neato BOTVAC CONNECTED Side Wheel Replacement: passo 16, immagine 2 di 2
    • Use the spudger to gently remove the paper filter.
  17. Neato BOTVAC CONNECTED Side Wheel Replacement, Side Wheel: passo 17, immagine 1 di 1
    • Remove the following screws with a TR10 Torx screwdriver:
    • Six 2.3 mm screws.
  18. Neato BOTVAC CONNECTED Side Wheel Replacement: passo 18, immagine 1 di 2 Neato BOTVAC CONNECTED Side Wheel Replacement: passo 18, immagine 2 di 2
    • Remove the front bumper by pulling it horizontally on each side.
  19. Neato BOTVAC CONNECTED Side Wheel Replacement: passo 19, immagine 1 di 1
    • Remove the screw that is directly attached to the wheel on the side using a Phillips #2 screwdriver.
  20. Neato BOTVAC CONNECTED Side Wheel Replacement: passo 20, immagine 1 di 1
    • Remove the two 2.3 mm screws on the front of the vacuum with a TR10 Torx screwdriver.
  21. Neato BOTVAC CONNECTED Side Wheel Replacement: passo 21, immagine 1 di 1
    • Remove the layer below the front bumper by pressing firmly on the two levers located nearby.
  22. Neato BOTVAC CONNECTED Side Wheel Replacement: passo 22, immagine 1 di 3 Neato BOTVAC CONNECTED Side Wheel Replacement: passo 22, immagine 2 di 3 Neato BOTVAC CONNECTED Side Wheel Replacement: passo 22, immagine 3 di 3
    • Gently take out the top panel, and take out the connecting wires.
  23. Neato BOTVAC CONNECTED Side Wheel Replacement: passo 23, immagine 1 di 1
    • Two 2.3 mm screws.
  24. Neato BOTVAC CONNECTED Side Wheel Replacement: passo 24, immagine 1 di 1
    • Flip around the vacuum and remove the wheel with the spudger.
Conclusione
Justin Silva
Membro da: 03/20/23
645 Reputazione
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 21
Tutti i Tempi: 279
