Introduzione
In this guide you will be able to replace the side brush of the Neato Botvac Connected. Replacing the side brush would be necessary if its not spinning properly. This could also be replaced if there are excess debris stuck in the brush. As a precaution make sure to disconnect the battery before beginning this guide.
Cosa ti serve
Remove the following screws with a Torx screwdriver:
Four 2.3 mm screws.
Quasi finito!
Conclusione
