Introduzione
Have you ever brought nail clippers on a trip, only to find that they had fallen apart in your bag. Before buying a new pair, try fixing them with this simple guide. As long as you have all three necessary parts, if you follow these easy steps your nail clippers will be as good as new.
Insert the rod through the bottom hole of the clipper body, and continue through the top hole.
The side of the rod with the notch should be inserted first.
Compress the body of the clippers to reveal the notch.
It is really hard for me to do this with one hand. help?
Me too it’s hard
Swivel the lever into its normal position, and test the nail clippers' functionality.
If you follow these steps, your nail clippers should be back to working order.
Altre 73 persone hanno completato questa guida.
17 Commenti
Thank you. Knew it was simple! Love this website.
This is the dumbest “repair guide” I have ever seen. It is not a repair, because they are not broken, it’s a re-assembly.
That's why it says reassembly 🤨
Thank you so much!!!! I could only find one pair in my house and was feeling desperate. This is the best guide to repair and I’m glad you posted under broken nail clippers because that’s what I considered mine to be and how I looked it up.
I used you steps, but whenever I try to rotate the handle so that I can clip my nails the handle just pops off again.
Albert E, the name of the website is “Nail Clipper Reassembly” you are not prooving a point. Its not dumb either because everyone else’s nail clippers work now. And the deffintion of repair is…
re·pair1
/rəˈper/
verb
1.
fix or mend (a thing suffering from damage or a fault). Or put something back together.
"faulty electrical appliances should be repaired by an electrician"
synonyms:mend, fix (up), put right, set right, restore, restore to working order, make as good as new, patch up, overhaul, service, renovate, recondition, rehabilitate, rebuild, reconstruct, refit, adjust, regulate; More
noun
where would you find a replacement pin? Mine is bent beyond repair. mymothersblessing@yahoo.com.
its good idk what else to say
Perfect instructions!
Came home drunkk; stepped on my toenaiil clippers; googled how do I fix my toenail clippers; found your tutorial, and I fixed them!!!
I may not remember this tomorrow, but your tutorial was great. Thank you
I fixed my clippers with your instructions 😊
Saved me from my hang nail. Thank you.
Like most things in life, when you get shown the proper way of doing things, it becomes simple. Thanks for the help.
Amazing stuff, thank you!
