Salta al contenuto principale
Nail Clipper Reassembly
  1. Nail Clipper Reassembly, Nail Clipper Reassembly: passo 1, immagine 1 di 3 Nail Clipper Reassembly, Nail Clipper Reassembly: passo 1, immagine 2 di 3 Nail Clipper Reassembly, Nail Clipper Reassembly: passo 1, immagine 3 di 3
    • Insert the rod through the bottom hole of the clipper body, and continue through the top hole.
    • The side of the rod with the notch should be inserted first.
    • Note: The top of the clipper body will often have a pick/file attached to it. If no pick/file is present, either side can serve as the top or the bottom.
  2. Nail Clipper Reassembly: passo 2, immagine 1 di 1
    • Compress the body of the clippers to reveal the notch.
  3. Nail Clipper Reassembly: passo 3, immagine 1 di 1
    • Rotate the rod until the notch opening faces away from the body.
    • This allows for easier completion of the following step.
  4. Nail Clipper Reassembly: passo 4, immagine 1 di 3 Nail Clipper Reassembly: passo 4, immagine 2 di 3 Nail Clipper Reassembly: passo 4, immagine 3 di 3
    • Place the hole of the lever into the revealed rod notch.
    • Release the compressed nail clipper body to lock the lever into place.
    • Note: Position of the lever does not matter at this point.
  5. Nail Clipper Reassembly: passo 5, immagine 1 di 3 Nail Clipper Reassembly: passo 5, immagine 2 di 3 Nail Clipper Reassembly: passo 5, immagine 3 di 3
    • Swivel the lever into its normal position, and test the nail clippers' functionality.
Conclusione
If you follow these steps, your nail clippers should be back to working order.
Altre 73 persone hanno completato questa guida.
Robert Weber
Membro da: 04/09/15
2.138 Reputazione
1 Guida realizzata
Cal Poly, Team 30-5, Green Spring 2015 Membro di Cal Poly, Team 30-5, Green Spring 2015
CPSU-GREEN-S15S30G5
5 Membri
31 Guide realizzate
17 Commenti
Thank you so much ! My fingers are arthritic and I was frustrated until I found your instructions.
marvin - Replica
Thank you. Knew it was simple! Love this website.
jonathanl.aguiar - Replica
This is the dumbest “repair guide” I have ever seen. It is not a repair, because they are not broken, it’s a re-assembly.
Albert E - Replica
That's why it says reassembly 🤨
Blake Jordan-Borns -
Thank you so much!!!! I could only find one pair in my house and was feeling desperate. This is the best guide to repair and I’m glad you posted under broken nail clippers because that’s what I considered mine to be and how I looked it up.
Tanya Bishop - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 60
Ultimi 7 Giorni: 519
Ultimi 30 Giorni: 2,459
Tutti i Tempi: 110,229
