Salta al contenuto principale
Nabi Jr Rear Case Replacement
Cosa ti serve
  1. Nabi Jr Rear Case Replacement, Rear Case: passo 1, immagine 1 di 1
    • Remove the red rubber case from the device. This should come off with ease.
  2. Nabi Jr Rear Case Replacement: passo 2, immagine 1 di 1
    • Turn the device so the screen is facing away from you.
    • Using a philips head, size #00, screwdriver, remove the screws in each corner of the plastic casing.(total of 4 screws)
  3. Nabi Jr Rear Case Replacement: passo 3, immagine 1 di 1
    • Remove the device casing using a small plastic pry bar.
    • This might take a little bit of force to accomplish, don't be afraid to go at it with a little gusto.
  4. Nabi Jr Rear Case Replacement: passo 4, immagine 1 di 1
    • After loosening the back cover, remove it from the device so you can get at the innards.
Conclusione
Tobias Young
Membro da: 03/24/15
27 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 7
Tutti i Tempi: 394
