Salta al contenuto principale
Nabi Jr Motherboard Replacement
Cosa ti serve
  1. Nabi Jr Motherboard Replacement, Rear Case: passo 1, immagine 1 di 1
    • Remove the red rubber case from the device. This should come off with ease.
  2. Nabi Jr Motherboard Replacement: passo 2, immagine 1 di 1
    • Turn the device so the screen is facing away from you.
    • Using a philips head, size #00, screwdriver, remove the screws in each corner of the plastic casing.(total of 4 screws)
  3. Nabi Jr Motherboard Replacement: passo 3, immagine 1 di 1
    • Remove the device casing using a small plastic pry bar.
    • This might take a little bit of force to accomplish, don't be afraid to go at it with a little gusto.
  4. Nabi Jr Motherboard Replacement: passo 4, immagine 1 di 1
    • After loosening the back cover, remove it from the device so you can get at the innards.
  5. Nabi Jr Motherboard Replacement, Motherboard: passo 5, immagine 1 di 1
    • Use the Philips #00 screwdriver to remove the 5 screws from the motherboard
  6. Nabi Jr Motherboard Replacement: passo 6, immagine 1 di 1
    • De-solder the grey wire from motherboard
  7. Nabi Jr Motherboard Replacement: passo 7, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use tweezers to peel off all yellow tape from the motherboard
    • Yellow tape is used in all locations where there is ribbon cable present.
  8. Nabi Jr Motherboard Replacement: passo 8, immagine 1 di 2 Nabi Jr Motherboard Replacement: passo 8, immagine 2 di 2
    • Remove all three ribbon cables from the motherboard by lifting up the locking tabs.
    • Pull black locking tabs up in opposite direction of ribbon cable to remove.
    • Use tweezers to pull the ribbon cable out of the locking tab's slot
  9. Nabi Jr Motherboard Replacement: passo 9, immagine 1 di 2 Nabi Jr Motherboard Replacement: passo 9, immagine 2 di 2
    • Lift motherboard to separate it the from the case shell.
Conclusione
Kaila Joy
Membro da: 03/24/15
86 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 1,171
