Salta al contenuto principale
Nabi Big Tab HD24 Screen Replacement
Cosa ti serve
  1. Nabi Big Tab HD24 Screen Replacement, Back Assembly: passo 1, immagine 1 di 1
    • Ensure that the tablet is facing you with the screen on the table.
    • Locate the four red rubber stops at the corners.
  2. Nabi Big Tab HD24 Screen Replacement: passo 2, immagine 1 di 1
    • Use your fingers to carefully peel them off the device to reveal the screws underneath.
  3. Nabi Big Tab HD24 Screen Replacement: passo 3, immagine 1 di 1
    • Use a Phillips #1 screwdriver to remove the 9.5 mm screw in each of the four corners.
  4. Nabi Big Tab HD24 Screen Replacement: passo 4, immagine 1 di 1
    • Flip the tablet over such that the screen is facing upwards.
    • Locate the the 4 small openings on the sides of the tablet.
    • There should be 2 on the bottom of the tablet, 1 on each side of the tablet viewing it from the front as if you were using it.
    • Do not confuse the openings with the charging port or the USB ports. The openings will be labelled with an icon of a small fan, the Nabi logo.
  5. Nabi Big Tab HD24 Screen Replacement: passo 5, immagine 1 di 1
    • Insert a metal spudger into one of the openings and carefully pop the device open by applying a steady downward force.
    • Repeat for the other three openings.
  6. Nabi Big Tab HD24 Screen Replacement: passo 6, immagine 1 di 2 Nabi Big Tab HD24 Screen Replacement: passo 6, immagine 2 di 2
    • Flip the device over so that the back assembly is facing you.
    • Use a plastic opening tool to carefully pry open the device from its hinges.
    • Take care when opening the device as there are cables running internally that are connected to both the front and the back assemblies.
  7. Nabi Big Tab HD24 Screen Replacement: passo 7, immagine 1 di 2 Nabi Big Tab HD24 Screen Replacement: passo 7, immagine 2 di 2
    • Locate the white port that connects the back panel to the circuit board on the back of the display.
    • Carefully pull the plastic connector straight out.
  8. Nabi Big Tab HD24 Screen Replacement: passo 8, immagine 1 di 1
    • Be careful of the aluminum foil tape, as it can easily rip.
    • Carefully lift up the aluminum foil tape with your fingers so that the ribbon connector reveals itself.
    • Do not try to pull the ribbon cables off the screen as there is a plastic piece surrounding the ribbon cables glued onto the metal display.
  9. Nabi Big Tab HD24 Screen Replacement: passo 9, immagine 1 di 1
    • Firmly press the two switches located on the sides of the connector and disconnect the connector from its connections.
    • Leave the connector disconnected but still intact with the metal display.
  10. Nabi Big Tab HD24 Screen Replacement: passo 10, immagine 1 di 1
    • Use a plastic opening tool and carefully push it underneath the grey plastic case surrounding the ribbon cable.
    • Apply a downward force to carefully peel the grey plastic off of the metal display.
  11. Nabi Big Tab HD24 Screen Replacement: passo 11, immagine 1 di 1
    • Locate the two cables running on both sides of the device found at the bottom side of the screen.
  12. Nabi Big Tab HD24 Screen Replacement: passo 12, immagine 1 di 2 Nabi Big Tab HD24 Screen Replacement: passo 12, immagine 2 di 2
    • Carefully grab both sides of the white plastic piece with your fingers and gently pull directly upward.
    • Do not pull from the red and black cable as it is not very sturdy and may come undone from the connector.
  13. Nabi Big Tab HD24 Screen Replacement, Screen: passo 13, immagine 1 di 1
    • Take out the two black 4.5 mm screws with your Phillips # 1 screwdriver and remove the circuit board.
    • You want to remove this circuit board so you can remove the silver screw that the circuit board is blocking.
  14. Nabi Big Tab HD24 Screen Replacement: passo 14, immagine 1 di 2 Nabi Big Tab HD24 Screen Replacement: passo 14, immagine 2 di 2
    • Remove each of the 6.5 mm silver screws located on the edges of the display's corners.
  15. Nabi Big Tab HD24 Screen Replacement: passo 15, immagine 1 di 1
    • Use a heating gun to heat up the side up the side of the screen you want to pry open.
    • Evenly distribute the heat around the frame of the screen for optimal results.
    • Do not focus the heat on one specific point for long periods of time as this may cause the glass to crack.
  16. Nabi Big Tab HD24 Screen Replacement: passo 16, immagine 1 di 1
    • Place several iOpeners along the sides of the screen that you are not heating up with the heat gun.
    • Spread them out around the device so the heat can evenly melt the adhesive on the screen.
    • Be careful when handling the iOpeners as they are hot and contain a gel that can burn skin if exposed from the packet.
  17. Nabi Big Tab HD24 Screen Replacement: passo 17, immagine 1 di 1
    • Use the jimmy and stick it in between the screen and the frame and wiggle the jimmy around to try and loosen the glass screen from the frame.
    • It may take some strength and patience since the adhesive is still very sticky.
  18. Nabi Big Tab HD24 Screen Replacement: passo 18, immagine 1 di 1
    • Once you create a space between the screen and the frame stick an i fixit pick in the crack to keep the crack open.
    • Keep inserting more picks every time you create some space, so eventually the screen will be completely separated from the frame.
    • Use the plastic opening tool to carefully remove the screen from the frame.
Conclusione
Altre 2 persone hanno completato questa guida.
Kelvin Cao
Membro da: 10/06/16
437 Reputazione
3 Guide realizzate
Cal Poly, Team 4-1, Livingston Fall 2016 Membro di Cal Poly, Team 4-1, Livingston Fall 2016
CPSU-LIVINGSTON-F16S4G1
4 Membri
14 Guide realizzate
5 Commenti
Where do you get parts for this thing tho
Nicholas Jones - Replica
Any luck finding screen
daymiel Moore -
Where can you get this particular replacement screen?
Jay - Replica
did you ever find a screen?
LushLeah -
Im looking for a screen too. Any luck on a referral?
Katherine Champion - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 20
Tutti i Tempi: 3,406
