Salta al contenuto principale
Nabi 2S Disassembly
Cosa ti serve
  1. Nabi 2S Disassembly, Nabi 2S Disassembly: passo 1, immagine 1 di 1
    • Remove the red rubber case from the device.
  2. Nabi 2S Disassembly: passo 2, immagine 1 di 2 Nabi 2S Disassembly: passo 2, immagine 2 di 2
    • Make sure the screen is facing away from you and the back cover is facing you.
    • Using a Phillips #0 Screwdriver, unscrew the 3mm screws counter-clockwise in each corner of the plastic back cover. It will be a total of four screws. The smaller case on the back cover is attached to the main cover so it will not need to be removed.
  3. Nabi 2S Disassembly: passo 3, immagine 1 di 1
    • Using the plastic opening tool, remove the case.
    • Removing the case will take a bit of effort and force. We recommend using two hands and if possible another person to help. It will require some gusto.
    • It is helpful to pry at the corners first to loosen the case.
  4. Nabi 2S Disassembly: passo 4, immagine 1 di 1
    • After the back case is loosened, remove it from the device to change or access the battery.
Conclusione
Altre 2 persone hanno completato questa guida.
Marist, Team 1-4, Laflen Spring 2016 Membro di Marist, Team 1-4, Laflen Spring 2016
MARS-LAFLEN-S16S1G4
2 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 8
Tutti i Tempi: 575
