Salta al contenuto principale
Nabi 2 Internal Speakers Replacement
Cosa ti serve
  1. Nabi 2 Internal Speakers Replacement, Nabi 2 Back Cover Removal: passo 1, immagine 1 di 3 Nabi 2 Internal Speakers Replacement, Nabi 2 Back Cover Removal: passo 1, immagine 2 di 3 Nabi 2 Internal Speakers Replacement, Nabi 2 Back Cover Removal: passo 1, immagine 3 di 3
    • Remove the rubber bumper from the tablet.
  2. Nabi 2 Internal Speakers Replacement: passo 2, immagine 1 di 2 Nabi 2 Internal Speakers Replacement: passo 2, immagine 2 di 2
    • With a PH00 screwdriver, remove the four outermost screws from the back of the tablet.
  3. Nabi 2 Internal Speakers Replacement: passo 3, immagine 1 di 3 Nabi 2 Internal Speakers Replacement: passo 3, immagine 2 di 3 Nabi 2 Internal Speakers Replacement: passo 3, immagine 3 di 3
    • Carefully, insert a plastic opening tool into the seam of the device and begin gently prying the two plastic pieces apart.
    • Work the tool all the way around the device. Small plastic clips should release. If they do not, gently apply outwards pressure until the clips give.
    • Do not force the clips open, as they are fairly easy to break
  4. Nabi 2 Internal Speakers Replacement, Internal Speakers: passo 4, immagine 1 di 1
    • Using the soldering iron, detach the speaker's wires from the circuit board.
  5. Nabi 2 Internal Speakers Replacement: passo 5, immagine 1 di 3 Nabi 2 Internal Speakers Replacement: passo 5, immagine 2 di 3 Nabi 2 Internal Speakers Replacement: passo 5, immagine 3 di 3
    • Using a Phillips PH 000 screwdriver, unscrew the two 3 mm Phillips #000 screws on each side of the speakers that hold the speakers in place.
  6. Nabi 2 Internal Speakers Replacement: passo 6, immagine 1 di 1
    • Once the screws have been removed, remove the speakers from the device.
Conclusione
Michelle
Membro da: 02/09/16
851 Reputazione
4 Guide realizzate
USF Tampa, Team 4-3, Lacy Spring 2016 Membro di USF Tampa, Team 4-3, Lacy Spring 2016
USFT-LACY-S16S4G3
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 747
