Salta al contenuto principale
Nabi 2 Headphone Jack Replacement
Cosa ti serve
  1. Nabi 2 Headphone Jack Replacement, Nabi 2 Back Cover Removal: passo 1, immagine 1 di 3 Nabi 2 Headphone Jack Replacement, Nabi 2 Back Cover Removal: passo 1, immagine 2 di 3 Nabi 2 Headphone Jack Replacement, Nabi 2 Back Cover Removal: passo 1, immagine 3 di 3
    • Remove the rubber bumper from the tablet.
  2. Nabi 2 Headphone Jack Replacement: passo 2, immagine 1 di 2 Nabi 2 Headphone Jack Replacement: passo 2, immagine 2 di 2
    • With a PH00 screwdriver, remove the four outermost screws from the back of the tablet.
  3. Nabi 2 Headphone Jack Replacement: passo 3, immagine 1 di 3 Nabi 2 Headphone Jack Replacement: passo 3, immagine 2 di 3 Nabi 2 Headphone Jack Replacement: passo 3, immagine 3 di 3
    • Carefully, insert a plastic opening tool into the seam of the device and begin gently prying the two plastic pieces apart.
    • Work the tool all the way around the device. Small plastic clips should release. If they do not, gently apply outwards pressure until the clips give.
    • Do not force the clips open, as they are fairly easy to break
  4. Nabi 2 Headphone Jack Replacement, Screen: passo 4, immagine 1 di 3 Nabi 2 Headphone Jack Replacement, Screen: passo 4, immagine 2 di 3 Nabi 2 Headphone Jack Replacement, Screen: passo 4, immagine 3 di 3
    • Lay the tablet down flat and remove the yellow tape from the ZIF connector on each side
  5. Nabi 2 Headphone Jack Replacement: passo 5, immagine 1 di 3 Nabi 2 Headphone Jack Replacement: passo 5, immagine 2 di 3 Nabi 2 Headphone Jack Replacement: passo 5, immagine 3 di 3
    • Using a spudger, slide the brown tab forward on each side of the connector
    • Slide until the connector is completely loose, then separate the screen from the bottom half of the tablet
    • If the screen is not working correctly, you will need to replace the entire display assembly
  6. Nabi 2 Headphone Jack Replacement, Battery: passo 6, immagine 1 di 3 Nabi 2 Headphone Jack Replacement, Battery: passo 6, immagine 2 di 3 Nabi 2 Headphone Jack Replacement, Battery: passo 6, immagine 3 di 3
    • Use the spudger to pop the battery out of place and set it aside.
  7. Nabi 2 Headphone Jack Replacement: passo 7, immagine 1 di 3 Nabi 2 Headphone Jack Replacement: passo 7, immagine 2 di 3 Nabi 2 Headphone Jack Replacement: passo 7, immagine 3 di 3
    • Desolder the battery connection and remove the battery completely
    • Note the color order for future replacemement
  8. Nabi 2 Headphone Jack Replacement, Internal Speakers: passo 8, immagine 1 di 1
    • Using the soldering iron, detach the speaker's wires from the circuit board.
  9. Nabi 2 Headphone Jack Replacement: passo 9, immagine 1 di 3 Nabi 2 Headphone Jack Replacement: passo 9, immagine 2 di 3 Nabi 2 Headphone Jack Replacement: passo 9, immagine 3 di 3
    • Using a Phillips PH 000 screwdriver, unscrew the two 3 mm Phillips #000 screws on each side of the speakers that hold the speakers in place.
  10. Nabi 2 Headphone Jack Replacement: passo 10, immagine 1 di 1
    • Once the screws have been removed, remove the speakers from the device.
  11. Nabi 2 Headphone Jack Replacement, Motherboard: passo 11, immagine 1 di 2 Nabi 2 Headphone Jack Replacement, Motherboard: passo 11, immagine 2 di 2
    • Remove the seven 4 mm Phillips #000 screws with a PH#000 screwdriver
  12. Nabi 2 Headphone Jack Replacement: passo 12, immagine 1 di 3 Nabi 2 Headphone Jack Replacement: passo 12, immagine 2 di 3 Nabi 2 Headphone Jack Replacement: passo 12, immagine 3 di 3
    • Remove the tape that is attaching the motherboard to the plastic casing
  13. Nabi 2 Headphone Jack Replacement: passo 13, immagine 1 di 3 Nabi 2 Headphone Jack Replacement: passo 13, immagine 2 di 3 Nabi 2 Headphone Jack Replacement: passo 13, immagine 3 di 3
    • Remove the motherboard by lifting from the area indicated
  14. Nabi 2 Headphone Jack Replacement, Headphone Jack: passo 14, immagine 1 di 3 Nabi 2 Headphone Jack Replacement, Headphone Jack: passo 14, immagine 2 di 3 Nabi 2 Headphone Jack Replacement, Headphone Jack: passo 14, immagine 3 di 3
    • Desolder the six pins attaching the headphone jack to the motherboard
    • Remove headphone jack from motherboard
Conclusione
Amy
Membro da: 02/10/16
285 Reputazione
2 Guide realizzate
USF Tampa, Team 4-3, Lacy Spring 2016 Membro di USF Tampa, Team 4-3, Lacy Spring 2016
USFT-LACY-S16S4G3
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 7
Tutti i Tempi: 1,255
