Salta al contenuto principale
NVIDIA GeForce GTX 970 GPU Replacement
Cosa ti serve
  1. NVIDIA GeForce GTX 970 GPU Replacement, GPU: passo 1, immagine 1 di 2 NVIDIA GeForce GTX 970 GPU Replacement, GPU: passo 1, immagine 2 di 2
    • Unplug all the external cables from the computer and ensure that the power supply is switched off.
  2. NVIDIA GeForce GTX 970 GPU Replacement: passo 2, immagine 1 di 2 NVIDIA GeForce GTX 970 GPU Replacement: passo 2, immagine 2 di 2
    • Remove the case side panel by applying pressure to the side and sliding the side panel toward the back of the case.
    • Some cases may have screws that must be removed or tabs that must be pressed before the siding will slide off.
  3. NVIDIA GeForce GTX 970 GPU Replacement: passo 3, immagine 1 di 3 NVIDIA GeForce GTX 970 GPU Replacement: passo 3, immagine 2 di 3 NVIDIA GeForce GTX 970 GPU Replacement: passo 3, immagine 3 di 3
    • Pinch the lock at the end of the GPU power cable and carefully disconnect it.
  4. NVIDIA GeForce GTX 970 GPU Replacement: passo 4, immagine 1 di 3 NVIDIA GeForce GTX 970 GPU Replacement: passo 4, immagine 2 di 3 NVIDIA GeForce GTX 970 GPU Replacement: passo 4, immagine 3 di 3
    • Remove the two Philips #1 mounting screws that attach the GPU to the inside of the case.
  5. NVIDIA GeForce GTX 970 GPU Replacement: passo 5, immagine 1 di 3 NVIDIA GeForce GTX 970 GPU Replacement: passo 5, immagine 2 di 3 NVIDIA GeForce GTX 970 GPU Replacement: passo 5, immagine 3 di 3
    • Press down the locking tab at the base of the GPU.
  6. NVIDIA GeForce GTX 970 GPU Replacement: passo 6, immagine 1 di 1
    • Remove the GPU from the case. If it does not move, check to make sure that steps 3-5 were properly performed.
  7. NVIDIA GeForce GTX 970 GPU Replacement: passo 7, immagine 1 di 2 NVIDIA GeForce GTX 970 GPU Replacement: passo 7, immagine 2 di 2
    • When inserting a replacement GPU, ensure that the base is lined up properly with the appropriate slot on the motherboard.
    • Once the replacement GPU is lined up, press down until you hear a click or can see that the locking tab is flipped up again.
Conclusione
To finish reassembly, follow steps 2-4 in reverse order.
Altre 11 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 21
Ultimi 30 Giorni: 75
Tutti i Tempi: 6,370
