Salta al contenuto principale
NP-R540-JA09US Keyboard Replacement
Cosa ti serve
  1. NP-R540-JA09US Keyboard Replacement, Battery: passo 1, immagine 1 di 1
    • Turn off laptop before starting.
    • Remove power cable before starting.
    • Flip the laptop over so that the bottom of the laptop is facing upwards.
    Chiedi a FixBot
  2. NP-R540-JA09US Keyboard Replacement: passo 2, immagine 1 di 1
    • Pull the two latches outward.
    Chiedi a FixBot
  3. NP-R540-JA09US Keyboard Replacement: passo 3, immagine 1 di 2 NP-R540-JA09US Keyboard Replacement: passo 3, immagine 2 di 2
    • Slide the battery out of the laptop.
    Chiedi a FixBot
  4. NP-R540-JA09US Keyboard Replacement, Optical Drive: passo 4, immagine 1 di 1
    • Remove securing screw with the PH0 head.
    Chiedi a FixBot
  5. NP-R540-JA09US Keyboard Replacement: passo 5, immagine 1 di 1
    • Slide the optical drive out and remove it from the device.
    Chiedi a FixBot
  6. NP-R540-JA09US Keyboard Replacement, Keyboard: passo 6, immagine 1 di 1
    • Remove the two Phillips #0 screws labeled KBD.
    Chiedi a FixBot
    • There are 5 clips along the top of the keyboard. Insert a thin opener tool (iSessamo tool or similar) between each clip and the keyboard tray to release it.
    • Make sure to pry the metal keyboard base and not the keycaps.
    Chiedi a FixBot
  7. NP-R540-JA09US Keyboard Replacement: passo 8, immagine 1 di 1
    • Do not bend your keyboard as shown in this picture.
    • Lift the keyboard up to release catches on the sides, then slide the keyboard towards the screen to slide tabs out of the slots at the bottom.
    Chiedi a FixBot
  8. NP-R540-JA09US Keyboard Replacement: passo 9, immagine 1 di 2 NP-R540-JA09US Keyboard Replacement: passo 9, immagine 2 di 2
    • Disconnect the keyboard cable from the motherboard.
    Chiedi a FixBot
Conclusione
Altre 2 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 11
Ultimi 30 giorni: 83
Tutti i Tempi: 1,264
