Salta al contenuto principale
NIkon Coolpix A900 I/O Cover Replacement
Cosa ti serve
  1. NIkon Coolpix A900 I/O Cover Replacement, Battery: passo 1, immagine 1 di 1
    • Orient the camera so that it is upside down, with the lens facing towards you.
  2. NIkon Coolpix A900 I/O Cover Replacement: passo 2, immagine 1 di 2 NIkon Coolpix A900 I/O Cover Replacement: passo 2, immagine 2 di 2
    • Slide the battery door lock left to unlock it.
    • The battery door will automatically open.
  3. NIkon Coolpix A900 I/O Cover Replacement: passo 3, immagine 1 di 2 NIkon Coolpix A900 I/O Cover Replacement: passo 3, immagine 2 di 2
    • Slide the yellow tab up to release the battery.
    • To re-insert a battery, slide the battery back in until the yellow tab locks it in place.
    • There is a diagram on the opposite side of the battery compartment to help you orient the battery correctly.
  4. NIkon Coolpix A900 I/O Cover Replacement, Rear Case: passo 4, immagine 1 di 3 NIkon Coolpix A900 I/O Cover Replacement, Rear Case: passo 4, immagine 2 di 3 NIkon Coolpix A900 I/O Cover Replacement, Rear Case: passo 4, immagine 3 di 3
    • Orient the camera upside down, with the lens facing away from you.
    • Remove the two 3mm Phillips #00 screws from the right.
    • Remove the two 3.4mm Phillips #00 screws from the left.
  5. NIkon Coolpix A900 I/O Cover Replacement: passo 5, immagine 1 di 3 NIkon Coolpix A900 I/O Cover Replacement: passo 5, immagine 2 di 3 NIkon Coolpix A900 I/O Cover Replacement: passo 5, immagine 3 di 3
    • Turn the camera on its side, with the lens facing away from you.
    • Remove the 3.4mm Phillips #00 screw. Repeat this for the opposite side of the camera.
  6. NIkon Coolpix A900 I/O Cover Replacement: passo 6, immagine 1 di 3 NIkon Coolpix A900 I/O Cover Replacement: passo 6, immagine 2 di 3 NIkon Coolpix A900 I/O Cover Replacement: passo 6, immagine 3 di 3
    • Place the camera upright with the lens facing away from you.
    • Move the monitor down, and remove two 4.4 mm screws.
  7. NIkon Coolpix A900 I/O Cover Replacement: passo 7, immagine 1 di 2 NIkon Coolpix A900 I/O Cover Replacement: passo 7, immagine 2 di 2
    • Remove the two black 2.5 mm screws from the monitor bracket.
  8. NIkon Coolpix A900 I/O Cover Replacement: passo 8, immagine 1 di 2 NIkon Coolpix A900 I/O Cover Replacement: passo 8, immagine 2 di 2
    • Return the monitor to the closed position.
    • Gently open the rear case.
    • You may need opening tools to help separate the rear case.
    • Be careful when opening the rear case to not damage the ribbon connectors.
  9. NIkon Coolpix A900 I/O Cover Replacement: passo 9, immagine 1 di 3 NIkon Coolpix A900 I/O Cover Replacement: passo 9, immagine 2 di 3 NIkon Coolpix A900 I/O Cover Replacement: passo 9, immagine 3 di 3
    • Place the camera lens down, while supporting the rear case.
    • Unlock the two ribbons by using your finger to lift the plastic hinge on the ribbon connector.
    • With the ribbons disconnected, you can now remove the rear case.
  10. NIkon Coolpix A900 I/O Cover Replacement, I/O Cover: passo 10, immagine 1 di 3 NIkon Coolpix A900 I/O Cover Replacement, I/O Cover: passo 10, immagine 2 di 3 NIkon Coolpix A900 I/O Cover Replacement, I/O Cover: passo 10, immagine 3 di 3
    • Locate the I/O cover on the rear case.
    • On the inside of the case, unhook the I/O cover by lifting up.
    • You may not need the spudger to remove the cover.
  11. NIkon Coolpix A900 I/O Cover Replacement: passo 11, immagine 1 di 1
    • Remove the I/O cover by gently pulling away from the rear case.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 424
