Salta al contenuto principale
NETGEAR WGT624 v3 Capacitor Replacement
Cosa ti serve
  1. NETGEAR WGT624 v3 Capacitor Replacement, Lower Case: passo 1, immagine 1 di 1
    • Turn the device so that the bottom is facing up.
  2. NETGEAR WGT624 v3 Capacitor Replacement: passo 2, immagine 1 di 3 NETGEAR WGT624 v3 Capacitor Replacement: passo 2, immagine 2 di 3 NETGEAR WGT624 v3 Capacitor Replacement: passo 2, immagine 3 di 3
    • Use the plastic opening tool to carefully lift the rubber stops in each corner.
    • Do not completely remove the rubber stops, because they are difficult to replace.
  3. NETGEAR WGT624 v3 Capacitor Replacement: passo 3, immagine 1 di 2 NETGEAR WGT624 v3 Capacitor Replacement: passo 3, immagine 2 di 2
    • Unscrew the 4 11.8 mm T-8 Torx screws from each corner of the device.
  4. NETGEAR WGT624 v3 Capacitor Replacement: passo 4, immagine 1 di 2 NETGEAR WGT624 v3 Capacitor Replacement: passo 4, immagine 2 di 2
    • Lift the lower case straight up from the rest of the router.
  5. NETGEAR WGT624 v3 Capacitor Replacement, Motherboard: passo 5, immagine 1 di 2 NETGEAR WGT624 v3 Capacitor Replacement, Motherboard: passo 5, immagine 2 di 2
    • Remove the clear plastic casing by lifting it straight up from the router.
  6. NETGEAR WGT624 v3 Capacitor Replacement: passo 6, immagine 1 di 2 NETGEAR WGT624 v3 Capacitor Replacement: passo 6, immagine 2 di 2
    • Separate the motherboard from the top shell by lifting it straight up from the router.
  7. NETGEAR WGT624 v3 Capacitor Replacement, Capacitor: passo 7, immagine 1 di 1
    • Turn the motherboard so that the top is facing upwards.
    • Place the motherboard on a clean flat surface.
  8. NETGEAR WGT624 v3 Capacitor Replacement: passo 8, immagine 1 di 1
    • Locate the four capacitors.
  9. NETGEAR WGT624 v3 Capacitor Replacement: passo 9, immagine 1 di 2 NETGEAR WGT624 v3 Capacitor Replacement: passo 9, immagine 2 di 2
    • Turn the motherboard so that the bottom is facing upwards.
    • Locate the two soldered contacts for each capacitor.
  10. NETGEAR WGT624 v3 Capacitor Replacement: passo 10, immagine 1 di 2 NETGEAR WGT624 v3 Capacitor Replacement: passo 10, immagine 2 di 2
    • Do not refer to the pictures in this step for correct soldering and de-soldering techniques. They are solely for illustration purposes.
    • Desolder the soldered connections between the capacitors and the motherboard, and pull the capacitor from the motherboard.
    • For proper soldering and de-soldering techniques, refer here.
    • When reinstalling the capacitor, make sure the negative side of the capacitor is aligned with the shaded white region of the circle.
Conclusione
Cal Poly, Team 3-31, Amido Winter 2013 Membro di Cal Poly, Team 3-31, Amido Winter 2013
CPSU-AMIDO-W13S3G31
3 Membri
12 Guide realizzate
Un commento
my router NETGEAR WNR 612 WIFI LED NOT GLOWING PLEASE HLP ME IN REPAIRING
Vinod Kumar Polakonda - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 1,508
