Cosa ti serve
Turn the projector upside down.
Remove the lamp small plastic cover.
Unsrew two srews and put out the lamp.
Remove the rest of the srews from the bottom.
Remove the plastic buttom cover.
Unscrew four screws.
Detached plugged cables marked with green squares.
Remove motherboard.
Unscrew all the screws marked on the pictures and remove the small backplate.
Pull out the fan.
Remove screws Green are screws that are not seen in the picture.
After removing the top cover there are more screws
Remove four lances
Unsrew screws (blue), green screw is a bit hidden.
Remove upper backplate.
Unscrew the connector and pull it out.
To pull the electricity part we should remove other parts first since they stick to cables connected to other modules.
Remove screws.
Take out the lens housing. Inside the lens housing are several small mirrors so be careful they don't fall out and brake.
Remove screws.
Green marked screw is a bit hidden inside the case.
Unplug the side cable and you can take out the module.
Once the module is partly outside you can open the iron frame and unplug the other two black cables plugs into this module from each side.
Remove marked screws. Green is not seen in the picture but it is there.
Remove the plastic cover and you'll find a big fan under it.
Now you can pull out the big fan together with the electrical module 1.
