Introduzione
Replacing the Power supply will require soldering
Cosa ti serve
Place the monitor screen face up.
Pull the frame off by placing your fingers on the inside of the frame and pulling out and up, the frame should snap off.
Continue your way around the screen.
Make a note or use a pen to mark which plugs correspond to which colors. (Pink or Blue)
Remove the four plugs on the brown circuit board by pulling up on the tabs and wiggling them out. You could also use a spudger to help you lift little clips holding them in.
Attrezzo utilizzato in questo passaggio:Phillips #1 Screwdriver$5.49
Locate the large black power plug.
Using a Phillips #1 Screwdriver, unscrew the two 8mm colts holding the black tabs to the metal frame.
