Salta al contenuto principale
NEC LCD1770NX Capacitor Replacement
Cosa ti serve
  1. NEC LCD1770NX Capacitor Replacement, Stand: passo 1, immagine 1 di 2 NEC LCD1770NX Capacitor Replacement, Stand: passo 1, immagine 2 di 2
    • Place the monitor face down on a clean, flat surface.
  2. NEC LCD1770NX Capacitor Replacement: passo 2, immagine 1 di 2 NEC LCD1770NX Capacitor Replacement: passo 2, immagine 2 di 2
    • Firmly remove the back panel of the stand by pulling it up and away from the monitor.
  3. NEC LCD1770NX Capacitor Replacement: passo 3, immagine 1 di 2 NEC LCD1770NX Capacitor Replacement: passo 3, immagine 2 di 2
    • Unscrew the two 6mm Phillips PH2 screws to detach the stand enclosure from the stand.
  4. NEC LCD1770NX Capacitor Replacement: passo 4, immagine 1 di 2 NEC LCD1770NX Capacitor Replacement: passo 4, immagine 2 di 2
    • Firmly grasp the stand enclosure with your hand and slide it to base of stand.
  5. NEC LCD1770NX Capacitor Replacement: passo 5, immagine 1 di 1
    • Unscrew the two 14.5mm Phillips PH2 screws holding the stand to the monitor.
  6. NEC LCD1770NX Capacitor Replacement: passo 6, immagine 1 di 2 NEC LCD1770NX Capacitor Replacement: passo 6, immagine 2 di 2
    • Lift the the stand straight up to remove it.
  7. NEC LCD1770NX Capacitor Replacement, Monitor Enclosure: passo 7, immagine 1 di 3 NEC LCD1770NX Capacitor Replacement, Monitor Enclosure: passo 7, immagine 2 di 3 NEC LCD1770NX Capacitor Replacement, Monitor Enclosure: passo 7, immagine 3 di 3
    • Place the monitor screen face up.
    • Pull the frame off by placing your fingers on the inside of the frame and pulling out and up, the frame should snap off.
    • Continue your way around the screen.
  8. NEC LCD1770NX Capacitor Replacement: passo 8, immagine 1 di 3 NEC LCD1770NX Capacitor Replacement: passo 8, immagine 2 di 3 NEC LCD1770NX Capacitor Replacement: passo 8, immagine 3 di 3
    • Unscrew the two 7mm screws from the bottom of the button assembly.
    • Do not pull the button assembly out too quickly or with too much force! Damage to the wires can occur.
    • Pull the button assembly out a few inches and unplug the colored cables.
  9. NEC LCD1770NX Capacitor Replacement: passo 9, immagine 1 di 2 NEC LCD1770NX Capacitor Replacement: passo 9, immagine 2 di 2
    • Unscrew the gold colored 7mm Phillips PH000 screw holding the button assembly to the monitor.
    • Remove the button assembly from the monitor.
  10. NEC LCD1770NX Capacitor Replacement: passo 10, immagine 1 di 1
    • With the monitor face-down, unscrew the 5 7mm Phillips PH2 screws around the outside of the enclosure.
  11. NEC LCD1770NX Capacitor Replacement: passo 11, immagine 1 di 3 NEC LCD1770NX Capacitor Replacement: passo 11, immagine 2 di 3 NEC LCD1770NX Capacitor Replacement: passo 11, immagine 3 di 3
    • Unscrew the 2 14.5mm Phillips PH2 screws located on the raised center of the enclosure.
    • Carefully pull the enclosure off the monitor.
  12. NEC LCD1770NX Capacitor Replacement: passo 12, immagine 1 di 2 NEC LCD1770NX Capacitor Replacement: passo 12, immagine 2 di 2
    • Unscrew the 10 5mm Philips PH2 screws holding the metal casing to the monitor.
  13. NEC LCD1770NX Capacitor Replacement: passo 13, immagine 1 di 2 NEC LCD1770NX Capacitor Replacement: passo 13, immagine 2 di 2
    • Pull the the metal casing off of the monitor to reveal the motherboards.
  14. NEC LCD1770NX Capacitor Replacement, Power Circuit Board: passo 14, immagine 1 di 3 NEC LCD1770NX Capacitor Replacement, Power Circuit Board: passo 14, immagine 2 di 3 NEC LCD1770NX Capacitor Replacement, Power Circuit Board: passo 14, immagine 3 di 3
    • Make a note or use a pen to mark which plugs correspond to which colors. (Pink or Blue)
    • Remove the four plugs on the brown circuit board by pulling up on the tabs and wiggling them out. You could also use a spudger to help you lift little clips holding them in.
  15. NEC LCD1770NX Capacitor Replacement: passo 15, immagine 1 di 3 NEC LCD1770NX Capacitor Replacement: passo 15, immagine 2 di 3 NEC LCD1770NX Capacitor Replacement: passo 15, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Large Needle Nose Pliers
    Compra
    • Locate the several multi-wire connectors on the board.
    • These connect several parts of each board together and consist of several different colors of wires. There is also a zip-tie holding the two sets of wires together that you can cut if it is getting in your way.
    • Disconnect the three plastic connectors from the blue colored boards by pulling them up while wiggling them.
    • Some force is necessary, it may also help to use the Large Needle Nose Pliers.
  16. NEC LCD1770NX Capacitor Replacement: passo 16, immagine 1 di 1
    Phillips #1 Screwdriver
    $5.49
    Compra
    • Locate the large black power plug.
    • Using a Phillips #1 Screwdriver, unscrew the two 8mm colts holding the black tabs to the metal frame.
  17. NEC LCD1770NX Capacitor Replacement: passo 17, immagine 1 di 1
    • Locate and remove the gold colored 10mm Philips screw located near the black power plug. It holds in a wire that connects to the power plug.
  18. NEC LCD1770NX Capacitor Replacement: passo 18, immagine 1 di 2 NEC LCD1770NX Capacitor Replacement: passo 18, immagine 2 di 2
    • Remove 5 8mm Phillip1 screws, with a Philips 1 screwdriver, located in various places on the board.
  19. NEC LCD1770NX Capacitor Replacement: passo 19, immagine 1 di 2 NEC LCD1770NX Capacitor Replacement: passo 19, immagine 2 di 2
    • Lift the brown power supply board off of the frame and set it aside.
  20. NEC LCD1770NX Capacitor Replacement, Capacitor: passo 20, immagine 1 di 1
    • Find the faulty capacitor on the board.
    • Bad capacitors can be identified by swelling or bursting at the top.
  21. NEC LCD1770NX Capacitor Replacement: passo 21, immagine 1 di 1
    • Flip the board over and find the corresponding solder joints. Capacitors have two joints on the opposite side of the circuit board.
    • Make sure you identify the correct solder joints! We wouldn't want you to desolder the wrong component!
    • Remember which direction the white stripe on the capacitor is facing! Orientation is important for a capacitor! The markings on the board should also remind which way to face the capacitor.
  22. NEC LCD1770NX Capacitor Replacement: passo 22, immagine 1 di 2 NEC LCD1770NX Capacitor Replacement: passo 22, immagine 2 di 2
    • Use a Soldering Station and Desoldering Braid to remove the solder from the two joints.
  23. NEC LCD1770NX Capacitor Replacement: passo 23, immagine 1 di 2 NEC LCD1770NX Capacitor Replacement: passo 23, immagine 2 di 2
    • Remove the capacitor from the board, you may need to straighten out the leads before you can take it out easily.
Conclusione
Charlie Mohr
Membro da: 10/21/13
353 Reputazione
3 Guide realizzate
Cal Poly, Team 11-36, Amido Fall 2013 Membro di Cal Poly, Team 11-36, Amido Fall 2013
CPSU-AMIDO-F13S11G36
5 Membri
7 Guide realizzate
Un commento
Hi, the content was comprehensive. Please comment on the electrolytic capacitor . Thank you.
fc fcbuy - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 16
Tutti i Tempi: 1,055
