Salta al contenuto principale
NABI XD Speakers Replacement
Cosa ti serve
  1. NABI XD Speakers Replacement, Rear panel: passo 1, immagine 1 di 2 NABI XD Speakers Replacement, Rear panel: passo 1, immagine 2 di 2
    • Use the plastic opening tool at the top left corner seam, then pry the corner apart.
  2. NABI XD Speakers Replacement: passo 2, immagine 1 di 1
    • Next slide the plastic opening tool across the sides of the Nabi. It will slowly open.
    • There are small plastic clips that need to be release. Gently apply outwards pressure until the clips give.
    • Go around the NABI XD and separate the rear panel from the device.
  3. NABI XD Speakers Replacement, Battery: passo 3, immagine 1 di 2 NABI XD Speakers Replacement, Battery: passo 3, immagine 2 di 2
    • Place your fingernails on both sides of the connector and pull it straight back away from the holder.
  4. NABI XD Speakers Replacement: passo 4, immagine 1 di 1
    • Battery is glued to the base, lift carefully.
    • To remove battery, lift the battery up from the motherboard.
  5. NABI XD Speakers Replacement, Charging port: passo 5, immagine 1 di 2 NABI XD Speakers Replacement, Charging port: passo 5, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Remove the two 4mm Phillips screws with the PH#0 screwdriver.
    • Disconnect the left (L) speaker wire from the charging port by grabbing it on both sides with the tweezers and pulling straight back.
  6. NABI XD Speakers Replacement: passo 6, immagine 1 di 1
    • Use your fingernails or a spudger to flip up the small retaining flap, then pull the ribbon straight back to remove
    • Lift the charging port from the NABI XD.
  7. NABI XD Speakers Replacement, Motherboard: passo 7, immagine 1 di 3 NABI XD Speakers Replacement, Motherboard: passo 7, immagine 2 di 3 NABI XD Speakers Replacement, Motherboard: passo 7, immagine 3 di 3
    • To remove the marked ribbons, use your fingernails or a spudger to lift up small tab
    • Use the Precision Tweezers to gently pull the ribbons straight out of the connectors.
    • You need to remove 4 ribbons
  8. NABI XD Speakers Replacement: passo 8, immagine 1 di 3 NABI XD Speakers Replacement: passo 8, immagine 2 di 3 NABI XD Speakers Replacement: passo 8, immagine 3 di 3
    • Disconnect the camera by lifting the ribbon straight up. Also disconnect the remaining ribbon by lifting up gently.
    • To disconnect antenna wire, use the tweezers to pry connector straight from the board.
  9. NABI XD Speakers Replacement: passo 9, immagine 1 di 2 NABI XD Speakers Replacement: passo 9, immagine 2 di 2
    • Disconnect the Right speaker by grabbing the wire head by its sides and pulling it back from the connector.
  10. NABI XD Speakers Replacement: passo 10, immagine 1 di 2 NABI XD Speakers Replacement: passo 10, immagine 2 di 2
    • Remove the four 4mm Phillips screws with the PH#0 screwdriver.
  11. NABI XD Speakers Replacement: passo 11, immagine 1 di 1
    • Lift the motherboard up away from the Nabi XD.
  12. NABI XD Speakers Replacement, Speakers: passo 12, immagine 1 di 3 NABI XD Speakers Replacement, Speakers: passo 12, immagine 2 di 3 NABI XD Speakers Replacement, Speakers: passo 12, immagine 3 di 3
    • Right (R) speaker removal:
    • Remove one 4mm Phillips screw.
    • Use the metal spudger to separate the speaker from the frame.
    • The speaker is glued to the Nabi XD it will require some force to separate them.
  13. NABI XD Speakers Replacement: passo 13, immagine 1 di 2 NABI XD Speakers Replacement: passo 13, immagine 2 di 2
    • Remove the left (L) speaker wire from the frame by pulling it to the side and up.
    • The wire in this step, is connected to the charging port. Removing it, is shown in detail on step 6.
  14. NABI XD Speakers Replacement: passo 14, immagine 1 di 3 NABI XD Speakers Replacement: passo 14, immagine 2 di 3 NABI XD Speakers Replacement: passo 14, immagine 3 di 3
    • Left (L) speaker removal:
    • Remove two 4mm Phillips screws.
Conclusione
USF Tampa, Team 17-2, Blackwell Fall 2016 Membro di USF Tampa, Team 17-2, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G2
3 Membri
12 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 12
Tutti i Tempi: 181
