Salta al contenuto principale
NABI XD Rear panel Replacement
Cosa ti serve
  1. NABI XD Rear panel Replacement, Rear panel: passo 1, immagine 1 di 2 NABI XD Rear panel Replacement, Rear panel: passo 1, immagine 2 di 2
    • Use the plastic opening tool at the top left corner seam, then pry the corner apart.
  2. NABI XD Rear panel Replacement: passo 2, immagine 1 di 1
    • Next slide the plastic opening tool across the sides of the Nabi. It will slowly open.
    • There are small plastic clips that need to be release. Gently apply outwards pressure until the clips give.
    • Go around the NABI XD and separate the rear panel from the device.
Conclusione
USF Tampa, Team 17-2, Blackwell Fall 2016 Membro di USF Tampa, Team 17-2, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G2
3 Membri
12 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 216
