Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
This guide should be used when replacing the motherboard or other components. Has the NABI XD taken water damaged or won't turn on after troubleshooting the charger. Then, replacing the motherboard will fix you device.
  1. Use the plastic opening tool at the top left corner seam, then pry the corner apart. Use the plastic opening tool at the top left corner seam, then pry the corner apart.
    • Use the plastic opening tool at the top left corner seam, then pry the corner apart.
  2. Next slide the plastic opening tool across the sides of the Nabi. It will slowly open.
    • Next slide the plastic opening tool across the sides of the Nabi. It will slowly open.
    • There are small plastic clips that need to be release. Gently apply outwards pressure until the clips give.
    • Go around the NABI XD and separate the rear panel from the device.
  3. Place your fingernails on both sides of the connector and pull it straight back away from the holder. Place your fingernails on both sides of the connector and pull it straight back away from the holder.
    • Place your fingernails on both sides of the connector and pull it straight back away from the holder.
  4. Battery is glued to the base, lift carefully.
    • Battery is glued to the base, lift carefully.
    • To remove battery, lift the battery up from the motherboard.
  5. STUDY UNPLUGGED
    Battery Fix Kits for Mac
    Shop Fix Kits
    STUDY UNPLUGGED
    Shop Fix Kits
  6. Remove the two 4mm Phillips screws with the PH#0 screwdriver. Disconnect the left (L) speaker wire from the charging port by grabbing it on both sides with the tweezers and pulling straight back.
    • Remove the two 4mm Phillips screws with the PH#0 screwdriver.
    • Disconnect the left (L) speaker wire from the charging port by grabbing it on both sides with the tweezers and pulling straight back.
  7. Use your fingernails or a spudger to flip up the small retaining flap, then pull the ribbon straight back to remove
    • Use your fingernails or a spudger to flip up the small retaining flap, then pull the ribbon straight back to remove
    • Lift the charging port from the NABI XD.
  8. To remove the marked ribbons, use your fingernails or a spudger to lift up small tab Use the Precision Tweezers to gently pull the ribbons straight out of the connectors. You need to remove 4 ribbons
    • To remove the marked ribbons, use your fingernails or a spudger to lift up small tab
    • Use the Precision Tweezers to gently pull the ribbons straight out of the connectors.
    • You need to remove 4 ribbons
  9. Disconnect the camera by lifting the ribbon straight up. Also disconnect the remaining ribbon by lifting up gently. To disconnect antenna wire, use the tweezers  to pry connector straight from the board. To disconnect antenna wire, use the tweezers  to pry connector straight from the board.
    • Disconnect the camera by lifting the ribbon straight up. Also disconnect the remaining ribbon by lifting up gently.
    • To disconnect antenna wire, use the tweezers to pry connector straight from the board.
  10. Disconnect the Right speaker by grabbing the wire head by its sides and pulling it back from the connector. Disconnect the Right speaker by grabbing the wire head by its sides and pulling it back from the connector.
    • Disconnect the Right speaker by grabbing the wire head by its sides and pulling it back from the connector.
  11. Remove the four 4mm Phillips  screws with the PH#0 screwdriver. Remove the four 4mm Phillips  screws with the PH#0 screwdriver.
    • Remove the four 4mm Phillips screws with the PH#0 screwdriver.
  12. Lift the motherboard up away from the Nabi XD.
    • Lift the motherboard up away from the Nabi XD.
Conclusione
USF Tampa, Team 17-2, Blackwell Fall 2016 Membro di USF Tampa, Team 17-2, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G2
3 Membri
12 Guide realizzate
Donde puedo conprar la pelicula de la tables o el displey y tatil
maria-201309 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 156
