Salta al contenuto principale
N-Strike Nite Finder EX-3 Battery Replacement
Cosa ti serve
  1. N-Strike Nite Finder EX-3 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • The batteries are located in the handle of the blaster.
    • The base plate is held in place with a single phillips head, 8.2 mm screw. Remove this screw and remove the base plate to access the battery compartment.
  2. N-Strike Nite Finder EX-3 Battery Replacement: passo 2, immagine 1 di 1
    • Once the batteries have been removed, you can check to see if they have any charge left in them with a battery tester.
    • If they are in fact dead, replace them with standard AA type batteries in the correct orientation.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 2,749
