Guida Studente in Evidenza
Questa guida è frutto del duro lavoro dei nostri bravissimi studenti e il nostro staff iFixit la trova eccezionalmente brillante.
Introduzione
Vai al passo 1 ↓A guide on how to replace a broken/non-functioning Joystick/D-pad on an MyArcade Mini Cabinet. This is for the Pac-Man version, be aware others can have differences in wiring and framing.
Tools needed:
- Precision Screwdriver & Flathead Screwdriver
- Hair Dryer
Replacement Parts:
- Replacement Silicone Pad
NOTE: This fix has many instances of screws. Be sure to properly group them together after a step to prevent confusion or swapping down the line.
Take your time reading and doing the steps carefully. Good luck!
Cosa ti serve
Strumenti
Flip the cabinet over and remove the four 10 mm-long Phillips #2 screws from the back casing of the cabinet.
Use a hairdryer to lightly heat the stickers on the side of the cabin.
Peel back the sticker far enough to reveal the screws.
Remove the three 5 mm-long Phillips screws underneath the stickers of each side of the cabinet.
After the last step, follow the process backwards to reassemble the cabinet back in proper condition.
Once done, Congrats! With careful time and proper handling, your cabinet is good to go again! Have fun playing, and thank you for listening and preventing E-Waste.
