Salta al contenuto principale
Munchkinz Speaker Replacement
Cosa ti serve
  1. Munchkinz Speaker Replacement, Opening Device: passo 1, immagine 1 di 1
    • Insert spudger into the USB Micro slot and pry the case apart.
    • Be careful not to go too deep and bend the prong inside the Micro USB port.
  2. Munchkinz Speaker Replacement, Pry Device Apart: passo 2, immagine 1 di 2 Munchkinz Speaker Replacement, Pry Device Apart: passo 2, immagine 2 di 2
    • Slide the wide plastic opening tool across the seem, separating it if you can't pry the device open using just the spudger.
    • Gently separate the case so none of the cords inside are disconnected
  3. Munchkinz Speaker Replacement, Separated Device: passo 3, immagine 1 di 1
    • After prying the device apart, it should look like this.
  4. Munchkinz Speaker Replacement, Pry Speaker: passo 4, immagine 1 di 2 Munchkinz Speaker Replacement, Pry Speaker: passo 4, immagine 2 di 2
    • Use the slim plastic opening tool to remove the speaker from its position on the case.
  5. Munchkinz Speaker Replacement, Locate Wires: passo 5, immagine 1 di 1
    • Locate the red and black wires that connect the speaker to the motherboard.
  6. Munchkinz Speaker Replacement, Solder Wires: passo 6, immagine 1 di 1
    • Un-solder the red and black speaker wires that are connected to the motherboard
Conclusione
David Wood
Membro da: 02/05/15
440 Reputazione
4 Guide realizzate
UW Tacoma, Team 3-6, Rose Winter 2015 Membro di UW Tacoma, Team 3-6, Rose Winter 2015
UWT-ROSE-W15S3G6
3 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 163
