Salta al contenuto principale
Munchkinz Motherboard Replacement
Cosa ti serve
  1. Munchkinz Motherboard Replacement, Opening Device: passo 1, immagine 1 di 1
    • Insert spudger into the USB Micro slot and pry the case apart.
    • Be careful not to go too deep and bend the prong inside the Micro USB port.
  2. Munchkinz Motherboard Replacement, Pry Device Apart: passo 2, immagine 1 di 2 Munchkinz Motherboard Replacement, Pry Device Apart: passo 2, immagine 2 di 2
    • Slide the wide plastic opening tool across the seem, separating it if you can't pry the device open using just the spudger.
    • Gently separate the case so none of the cords inside are disconnected
  3. Munchkinz Motherboard Replacement, Separated Device: passo 3, immagine 1 di 1
    • After prying the device apart, it should look like this.
  4. Munchkinz Motherboard Replacement, Pry Camera: passo 4, immagine 1 di 1
    • Use the slim plastic opening tool to pry the camera from its initial position.
  5. Munchkinz Motherboard Replacement, Disconnect Ribbon: passo 5, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use the precision tweezers to gently disconnect the camera ribbon that is connected to the motherboard.
  6. Munchkinz Motherboard Replacement, Pry Speaker: passo 6, immagine 1 di 2 Munchkinz Motherboard Replacement, Pry Speaker: passo 6, immagine 2 di 2
    • Use the slim plastic opening tool to remove the speaker from its position on the case.
  7. Munchkinz Motherboard Replacement, Locate Wires: passo 7, immagine 1 di 1
    • Locate the red and black wires that connect the speaker to the motherboard.
  8. Munchkinz Motherboard Replacement, Solder Wires: passo 8, immagine 1 di 1
    • Un-solder the red and black speaker wires that are connected to the motherboard
  9. Munchkinz Motherboard Replacement, Volume Button: passo 9, immagine 1 di 1
    • Remove the plastic volume button.
  10. Munchkinz Motherboard Replacement, Unscrew Module: passo 10, immagine 1 di 1
    • Remove the two screws that hold the volume button assembly in place.
  11. Munchkinz Motherboard Replacement, Solder Module Wires: passo 11, immagine 1 di 1
    • Un-solder the yellow, red, and black wires that connect the volume module to the motherboard.
  12. Munchkinz Motherboard Replacement, Removing battery: passo 12, immagine 1 di 3 Munchkinz Motherboard Replacement, Removing battery: passo 12, immagine 2 di 3 Munchkinz Motherboard Replacement, Removing battery: passo 12, immagine 3 di 3
    • Use the wide plastic opening tool to slowly pry each side of the battery up.
    • Be careful not to bend the battery too much.
  13. Munchkinz Motherboard Replacement, Remove battery completely: passo 13, immagine 1 di 1
    • Use the Soldering Iron to disconnect the each cable.
  14. Munchkinz Motherboard Replacement, Remove Tape: passo 14, immagine 1 di 1
    • Remove black tape covering any of the ribbons that have it.
  15. Munchkinz Motherboard Replacement, Remove Ribbons: passo 15, immagine 1 di 1
    • Pull the ribbons out from the plugs.
  16. Munchkinz Motherboard Replacement, Remove Camera/Hidden Screw: passo 16, immagine 1 di 1
    • After removing the camera, remove the hidden screw.
  17. Munchkinz Motherboard Replacement, Remove Screws: passo 17, immagine 1 di 1
    • Remove screws located on the opposite side of the battery.
  18. Munchkinz Motherboard Replacement, Lift: passo 18, immagine 1 di 1
    • Carefully lift up the motherboard. Your accessory parts such as battery, speaker, volume button assembly, and camera wires will be disconnected, not connected, like in this picture.
Conclusione
UW Tacoma, Team 3-6, Rose Winter 2015 Membro di UW Tacoma, Team 3-6, Rose Winter 2015
UWT-ROSE-W15S3G6
3 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 228
