Salta al contenuto principale
Munchkin Mozart Magic Cube Face plate Replacement
Cosa ti serve
  1. Munchkin Mozart Magic Cube Face plate  Replacement, Face plate: passo 1, immagine 1 di 2 Munchkin Mozart Magic Cube Face plate  Replacement, Face plate: passo 1, immagine 2 di 2
    • Remove two 6 mm Phillips #2 screws on either side of the On/Off Plate.
  2. Munchkin Mozart Magic Cube Face plate  Replacement: passo 2, immagine 1 di 1
    • Remove the On/Off switch plate and save the screws so you can use them later to put the plate back on.
  3. Munchkin Mozart Magic Cube Face plate  Replacement: passo 3, immagine 1 di 1
    • Gently pull out the battery cartridge and if needed, replace the batteries with 3 AA alkaline batteries.
  4. Munchkin Mozart Magic Cube Face plate  Replacement: passo 4, immagine 1 di 1
    • Starting with the yellow face, insert the metal spudger between the yellow face and the white frame, prying the frame apart.
  5. Munchkin Mozart Magic Cube Face plate  Replacement: passo 5, immagine 1 di 1
    • Insert the metal spudger in the space created by the plastic opening tool between the frame and face of the cube.
    • Pry the cube face from the frame.
  6. Munchkin Mozart Magic Cube Face plate  Replacement: passo 6, immagine 1 di 1
    • After removing the square plates, you can unscrew the screws underneath.
    • Remove four 6 mm Phillips #2 screws, located on the sides.
  7. Munchkin Mozart Magic Cube Face plate  Replacement: passo 7, immagine 1 di 1
    • Remove the rubber corners by simply pulling them off.
Conclusione
USF Tampa, Team 1-4, Sullivan Fall 2015 Membro di USF Tampa, Team 1-4, Sullivan Fall 2015
USFT-SULLIVAN-F15S1G4
4 Membri
14 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,357
