Salta al contenuto principale
Mt. Fury Roadmaster Pedal Replacement
Cosa ti serve
  1. Mt. Fury Roadmaster Pedal Replacement, Pedal: passo 1, immagine 1 di 1
    • Flip the bicycle upside down so that the bicycle rests on the seat and handlebars. The bike should be able to stay standing on its own.
  2. Mt. Fury Roadmaster Pedal Replacement: passo 2, immagine 1 di 3 Mt. Fury Roadmaster Pedal Replacement: passo 2, immagine 2 di 3 Mt. Fury Roadmaster Pedal Replacement: passo 2, immagine 3 di 3
    • Locate the 15mm pedal nut, and position the crank arms for maximum leverage.
    • Using a 15mm open-end wrench, brace the opposite pedal with your other hand and remove the pedal nut from the crank arm.
    • A considerable amount of force may be required to break pedal nut free.
Conclusione
To install new pedal, follow these instructions in reverse order.
Cal Poly, Team 1-40, Maness Winter 2014 Membro di Cal Poly, Team 1-40, Maness Winter 2014
CPSU-MANESS-W14S1G40
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 24
Ultimi 30 Giorni: 26
Tutti i Tempi: 2,498
