Salta al contenuto principale
Mt. Fury Roadmaster Brake Pad Replacement
Cosa ti serve
  1. Mt. Fury Roadmaster Brake Pad Replacement, Brake Pad: passo 1, immagine 1 di 2 Mt. Fury Roadmaster Brake Pad Replacement, Brake Pad: passo 1, immagine 2 di 2
    • Locate and remove the dome nut with a 10mm open-end wrench.
  2. Mt. Fury Roadmaster Brake Pad Replacement: passo 2, immagine 1 di 1
    • Inspect brake pad for wear.
  3. Mt. Fury Roadmaster Brake Pad Replacement: passo 3, immagine 1 di 1
    • Dome nut (left), lock washer (middle), and brake pad (right).
    • Be sure to save the dome nut and lock washer just in case the replacement brake shoe does not include them.
    • When installing the new brake shoe, make sure it is properly aligned so it is in full contact with the edge of the rim.
Conclusione
To install your new brake shoes, follow these instructions in reverse order.
Cal Poly, Team 1-40, Maness Winter 2014 Membro di Cal Poly, Team 1-40, Maness Winter 2014
CPSU-MANESS-W14S1G40
4 Membri
5 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 34
Tutti i Tempi: 2,129
