Salta al contenuto principale
Introduzione
Replacing the power cord on the TF6 requires several wiring tools and previous experience with soldering. For soldering tips and directions, consult the guide on how to solder and desolder connections.
  1. Facing the bottom of the TF6, carefully pull the two rubber feet out with your hands.
    • Facing the bottom of the TF6, carefully pull the two rubber feet out with your hands.
  2. Using a Phillips #1 screwdriver, remove the six 11mm Phillips screws that are holding the bottom cover in place. Using a Phillips #1 screwdriver, remove the six 11mm Phillips screws that are holding the bottom cover in place.
    • Using a Phillips #1 screwdriver, remove the six 11mm Phillips screws that are holding the bottom cover in place.
  3. Gently lift the bottom cover, detaching it from the main body of the TF6.
    • Gently lift the bottom cover, detaching it from the main body of the TF6.
  4. Using a Phillips #1 screwdriver, remove the two 13mm Phillips screws that are securing the wire harness.
    • Using a Phillips #1 screwdriver, remove the two 13mm Phillips screws that are securing the wire harness.
  5. Carefully lift the wire harness from the base of the TF6, detaching it completely.
    • Carefully lift the wire harness from the base of the TF6, detaching it completely.
    • The power cord wiring is now completely accessible.
  6. Using a set of wire cutters, cut both leads of the power cord at the heatshrinked area where the leads split. Using a set of wire cutters, cut both leads of the power cord at the heatshrinked area where the leads split.
    • Using a set of wire cutters, cut both leads of the power cord at the heatshrinked area where the leads split.
  7. Using your fingers, pry the heatshrink off from the power cord leads. Using your fingers, pry the heatshrink off from the power cord leads.
    • Using your fingers, pry the heatshrink off from the power cord leads.
  8. Using a 14-16 AWG wire stripper, strip the leads on the replacement power cord.
    • Using a 14-16 AWG wire stripper, strip the leads on the replacement power cord.
  9. Solder the power cord's positive lead to the white nylon wire.
    • Solder the power cord's positive lead to the white nylon wire.
    • Solder the power cord's ground lead to the bronze nylon wire.
    • Ensure the correct leads are being soldered together (power to power, ground to ground). Soldering the incorrect leads together will result in hazardous conditions for both the TF6 and the user when the unit is powered on.
    • Consult the replacement power cord's user manual, packaging, or manufacturer in order to verify the power and ground leads.
Conclusione
Andrew
Membro da: 24/01/2014
101 Reputazione
1 Guida realizzata
Cal Poly, Team 13-18, Regan Winter 2014 Membro di Cal Poly, Team 13-18, Regan Winter 2014
CPSU-REGAN-W14S13G18
4 Membri
5 Guide realizzate
Good tutorial, I like this
Sfapa - Replica
Excellent! very helpful...
NP Designs 123 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 606
