Introduzione
Leaks can occur within the Mr. Coffee TF6. In most cases, replacing the internal water tubes will correct this issue. You will require 2 inches of silicone tubing (.5 in. OD) to replace the original water tubes inside the TF6.
  1. Facing the bottom of the TF6, carefully pull the two rubber feet out with your hands.
    • Facing the bottom of the TF6, carefully pull the two rubber feet out with your hands.
  2. Using a Phillips #1 screwdriver, remove the six 11mm Phillips screws that are holding the bottom cover in place. Using a Phillips #1 screwdriver, remove the six 11mm Phillips screws that are holding the bottom cover in place.
    • Using a Phillips #1 screwdriver, remove the six 11mm Phillips screws that are holding the bottom cover in place.
  3. Gently lift the bottom cover, detaching it from the main body of the TF6.
    • Gently lift the bottom cover, detaching it from the main body of the TF6.
  4. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  5. Using your fingers, gently pinch and detach the two metal clips that secure the silicone tubing to the metal tubing on the TF6.
    • Using your fingers, gently pinch and detach the two metal clips that secure the silicone tubing to the metal tubing on the TF6.
  6. Carefully pull the silicon tubing off of the metal tubing.
    • Carefully pull the silicon tubing off of the metal tubing.
  7. Using a Phillips #1 screwdriver, remove the three 13mm Phillips screws that hold the lower and upper assemblies together.
    • Using a Phillips #1 screwdriver, remove the three 13mm Phillips screws that hold the lower and upper assemblies together.
  8. Gripping the lower assembly with one hand and the upper assembly with the other, gently pull the assemblies apart.
    • Gripping the lower assembly with one hand and the upper assembly with the other, gently pull the assemblies apart.
    • If all screws have been removed and the tubes have been detached, the assemblies should separate easily.
  9. Using your fingers, gently pinch and detach the two metal clips that secure the silicone tubing to the plastic tubes on the upper assembly.
    • Using your fingers, gently pinch and detach the two metal clips that secure the silicone tubing to the plastic tubes on the upper assembly.
  10. Carefully pull the silicon tubing off of the plastic tubing on the upper assembly.
    • Carefully pull the silicon tubing off of the plastic tubing on the upper assembly.
Conclusione
Jordan
Membro da: 31/01/2014
201 Reputazione
2 Guide realizzate
Cal Poly, Team 13-18, Regan Winter 2014 Membro di Cal Poly, Team 13-18, Regan Winter 2014
CPSU-REGAN-W14S13G18
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,102
