Salta al contenuto principale
Mr. Coffee DW13 Power Cord Replacement
Cosa ti serve
  1. Mr. Coffee DW13 Power Cord Replacement, Base: passo 1, immagine 1 di 2 Mr. Coffee DW13 Power Cord Replacement, Base: passo 1, immagine 2 di 2
    • Before performing this repair, be sure that your machine is unplugged and dry and that your work space is clean.
    • Flip the Mr. Coffee DW13 over so that the lid is facing away from you and the base is facing toward you.
  2. Mr. Coffee DW13 Power Cord Replacement: passo 2, immagine 1 di 2 Mr. Coffee DW13 Power Cord Replacement: passo 2, immagine 2 di 2
    • Remove the eight 11 mm screws that secure the base of the machine with a Phillips Head #2 screwdriver.
  3. Mr. Coffee DW13 Power Cord Replacement: passo 3, immagine 1 di 1
    • Gently lift the base cover to expose the inside of the coffee machine.
  4. Mr. Coffee DW13 Power Cord Replacement, Power Cord: passo 4, immagine 1 di 2 Mr. Coffee DW13 Power Cord Replacement, Power Cord: passo 4, immagine 2 di 2
    • Locate the white tab that covers and holds the power cord in place. It has two screws on either side of it.
    • Use a #2 Philips Head screwdriver to unscrew the two 13mm screws holding the tab in place.
  5. Mr. Coffee DW13 Power Cord Replacement: passo 5, immagine 1 di 2 Mr. Coffee DW13 Power Cord Replacement: passo 5, immagine 2 di 2
    • Gently lift up on the white tab, removing it from the coffee machine.
  6. Mr. Coffee DW13 Power Cord Replacement: passo 6, immagine 1 di 2 Mr. Coffee DW13 Power Cord Replacement: passo 6, immagine 2 di 2
    • Locate the 2 electrical connectors running from the black plastic-coated power cord to the interior of the power switch.
    • One cord is copper colored and ends at the power switch in a silver metal square.
    • The other cord is white and ends at the power switch in a black plastic square.
  7. Mr. Coffee DW13 Power Cord Replacement: passo 7, immagine 1 di 2 Mr. Coffee DW13 Power Cord Replacement: passo 7, immagine 2 di 2
    • Grasp the copper cord close to the power switch. Lightly pull the silver end tab from the end to detach it.
  8. Mr. Coffee DW13 Power Cord Replacement: passo 8, immagine 1 di 2 Mr. Coffee DW13 Power Cord Replacement: passo 8, immagine 2 di 2
    • Lightly pull the white cord away from the power switch by grasping the black plastic-coated head.
    • There are two white cords attached to each other. Pull them apart by grasping the different black heads and separating them.
  9. Mr. Coffee DW13 Power Cord Replacement: passo 9, immagine 1 di 3 Mr. Coffee DW13 Power Cord Replacement: passo 9, immagine 2 di 3 Mr. Coffee DW13 Power Cord Replacement: passo 9, immagine 3 di 3
    • Pull the power cord through the hole at the back of the base of the machine, followed by the two colored cords.
Conclusione
Altre 3 persone hanno completato questa guida.
Tess Bradley
Membro da: 01/26/14
373 Reputazione
3 Guide realizzate
Cal Poly, Team 10-31, Maness Winter 2014 Membro di Cal Poly, Team 10-31, Maness Winter 2014
CPSU-MANESS-W14S10G31
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 35
Tutti i Tempi: 3,189
